Creating a Product
Updated on 2022-12-05 GMT+08:00
Overview
A product is a device model, which is a set of service attributes of devices of the same type. Each device belongs to a product and inherits all service attributes of the product.
Product information includes basic information and thing model. It describes what a product is, what functions the product can provide, and what services the product can provide for external systems.
  • Basic information
    Describes basic information about a device, including the manufacturer name, manufacturer ID, product type, product model, protocol type, and device type. The product model and manufacturer ID are used together to identify a product.
    For example, the product model of a water meter is NBIoTDevice, the manufacturer name is HZYB, the manufacturer ID is TestUtf8ManuId, and the device type is WaterMeter.
  • Thing model
    Service capabilities of a device need to be defined. After the capabilities of a device are divided into multiple thing model services, define the attributes, commands, and command parameters of each thing model service.
    Take a water meter as an example. It has multiple capabilities, such as reporting data about the water flow, alarms, power, and connections, and receiving various commands delivered by a server. When describing the capabilities of a water meter, you can divide the capabilities into five thing model services, and define the attributes reported by each thing model service and their supported commands, as listed in the following table.
    Table 1 Service description
    Thing Model Service
    WaterMeterBasic
    Used to define parameters reported by the water meter, such as the water flow, temperature, and pressure. If these parameters need to be controlled or modified using commands, you also need to define parameters in the commands.
    WaterMeterAlarm
    Used to define data reported by the water meter in various alarm scenarios. Commands need to be defined if necessary.
    Battery
    Used to define data including the voltage and current intensity of the water meter.
    DeliverySchedule
    Used to define transmission rules for the water meter. Commands need to be defined if necessary.
    Connectivity
    Used to define connection parameters for the water meter.
    The number of thing model services defined depends on the requirements. In the preceding example, the alarm thing model service can be split into the water pressure alarm service and traffic alarm service, or the alarm service can be integrated into the basic water meter service.
Creating a Product
  1. Log in to the ROMA Connect console. On the Instances page, click View Console next to a specific instance.
  2. In the navigation pane on the left, choose LINK > Product Management. On the page displayed, click Create Product in the upper right corner.
  3. In the Create Product dialog box, set product parameters and click OK.
    Table 2 Parameters for creating a product
    Product Type
    Select a product type.
    • Common: indicates a directly connected device or a gateway subdevice.
    • Gateway: indicates a gateway product of the Edgeshell type.
    Protocol Type
    Select the protocol type used by the product.
    • MQTT: a publish-subscribe network protocol that transports messages between devices.
    • Modbus: a serial communication protocol.
    • OPC UA: an Ethernet-based communication protocol.
    Integration Application
    Select the integration application to which the product belongs.
    Product Template
    After a product template is selected, the created product has all services and attributes of the product template.
    Only product templates in the Enabled state can be selected.
    Product Name
    Enter a product name. It is recommended that you enter a name based on naming rules to facilitate search.
    Manufacturer Name
    Enter the manufacturer name of the device in use.
    Manufacturer ID
    Enter the manufacturer ID of the device in use.
    Product Model
    Enter the product model of the device in use.
    The product model and manufacturer ID collectively identify a product. The combination of product model and manufacturer ID must be unique.
    Device Type
    Select the type of the device to be connected. You can select Default Type or add a device type that is added in DEVICE_TYPE on the Data Dictionaries tab page of the Instances page. For details, see Creating a Data Dictionary.
    Model Version
    Enter a custom model version of the device.
    Enter a brief description of the product.
(Optional) Adding a Thing Model Service for a Product
  1. On the ROMA Connect console, choose LINK > Product Management and click a product name to access the product details page.
  2. Add thing model services for the product.
    1. On the Thing Model tab page, click Create.
    2. In the Create Thing Model Service dialog box, set thing model service parameters and click OK.
      Table 3 Parameters for creating a thing model service
      Name
      Enter a thing model service name. It is recommended that you enter a name based on naming rules to facilitate search.
      Status
      This parameter specifies whether to enable the thing model service. The thing model service is enabled by default.
      Enter a brief description of the thing model service.
  3. Add attributes for the thing model service.
    1. On the Thing Model tab page, select the thing model service for which you want to add attributes.
    2. On the Attributes tab page, click Create.
    3. In the Create Attribute dialog box, set attribute parameters and click OK.
      Table 4 Parameters for creating an attribute
      Name
      Enter an attribute name. It is recommended that you enter a name based on naming rules to facilitate search.
      Data Type
      Select the data type of the attribute.
      • Int: integer. If you select Int, you also need to specify Min. Value, Max. Value, Step, and Unit.
      • Number: number. If you select Number, you also need to specify Min. Value, Max. Value, Step, and Unit.
      • String: a character string. If you select String, you also need to specify Data Length and Enumerated Value.
      • Bool: Boolean. If you select Bool, you also need to specify 0 and 1.
      • Datetime: date. If you select Datatime, you also need to specify Data Length.
      • JsonObject: JSON object. If you select JsonObject, you also need to specify Data Length.
      • Array: array.
      The following uses the Int type as an example:
      When defining the temperature attribute for thermometers, set Type to Int, Min. Value to 0, Max. Value to 100, Step to 2, and Unit to °C. This indicates that the device reports the temperature value (for example, 0°C, 2°C, 4°C, 6°C and 8°C) each time the temperature changes by two degrees.
      Mandatory
      This parameter specifies whether the attribute must be reported by a device. This parameter is enabled by default.
      Enter a brief description of the attribute.
      Min. Value
      Enter the minimum value of the attribute. The value must be of the Int type.
      Max. Value
      Enter the maximum value of the attribute. The value must be of the Int type.
      Step
      Enter the step of the attribute. The value must be of the Int type.
      Unit
      Enter the unit of the attribute. The value cannot exceed 50 characters. For example, the unit of the temperature attribute can be °C.
  4. Add commands for the thing model service.
    1. On the Thing Model tab page, select the thing model service for which you want to add commands.
    2. On the Commands tab page, click Create.
    3. In the Create Command dialog box, set command parameters and click OK.
      Table 5 Parameters for creating a command
      Command Name
      Enter a command name. It is recommended that you enter a name based on naming rules to facilitate search.
      Enter a brief description of the command.
    4. Locate the created command in the command list and click next to the command name to expand the command field list.
      Click Delivery Command Fields or Response Command Fields on the right to view the delivery command fields and response command fields of the command.
    5. Click Create Field.
    6. In the Create Delivery Command Field or Create Response Command Field dialog box, set field parameters and click OK.
      Table 6 Parameters for creating a field
      Field Name
      Enter a field name. It is recommended that you enter a name based on naming rules to facilitate search.
      Data Type
      Select the data type of the command field.
      • Array: array.
      Mandatory
      This parameter specifies whether the field must be carried in the delivery command. By default, the field must be carried.
      Enter a brief description of the command field.
      Min. Value
      Enter the minimum value of the delivery command field. The value must be of the Int type.
      Max. Value
      Enter the maximum value of the delivery command field. The value must be of the Int type.
      Step
      Enter the step of the delivery command field. The value must be of the Int type.
      Unit
      Enter the unit of the delivery command field. The value cannot exceed 50 characters. For example, the unit of the voltage field can be V.
(Optional) Adding a Customized Topic for a Product
If the basic topics of a device cannot meet your requirements, you can customize a topic for the device. After the customized topic is added to a product, the topic is inherited by all devices under the product.
  2. On the Topic Classes tab page, click Create Topic.
  3. In the dialog box displayed, configure topic information and click OK.
    Table 7 Parameters for creating a topic
    Operation Permission
    Select the topic permission granted for the device.
    • Publishing: The device has the permission to publish messages into the topic.
    • Subscription: The device has the permission to subscribe to the topic and obtain messages from the topic.
    Topic Class Name
    Enter the custom field in the name of the custom topic. The version number, device ID, and customized fields form a custom topic name: /{Version number}/{Device ID}/{Custom field}.
    Version Number
    Enter the version number of the topic, for example, V1.0.
    Enter the brief description of the custom topic.
