- What's New
- Function Overview
- Billing
Getting Started
- Using a Public NAT Gateway to Enable Servers to Share One or More EIPs to Access the Internet
- Using a Public NAT Gateway to Enable Servers to Be Accessed by the Internet
- Using a Private NAT Gateway to Connect Cloud and On-premises Networks
- Using Multiple Public NAT Gateways Together in Performance-Demanding Scenarios
User Guide
- Public NAT Gateways
- Private NAT Gateways
- Permissions Management
- Tag Management
- Managing Quotas
- Monitoring
- Auditing
Best Practices
- Enabling Private Networks to Access the Internet Using a Cloud Connection and SNAT
- Using a Public NAT Gateway and Direct Connect to Accelerate Internet Access
- Using a Private NAT Gateway and Direct Connect to Enable Communications Between a VPC and an On-premises Data Center
- Using a Public NAT Gateway and VPC Peering to Enable Communications Between VPCs and the Internet
- Preserving Your Network with NAT Gateways During Cloud Migration
API Reference
- Before You Start
- API Overview
- Calling APIs
- APIs of Public NAT Gateways
- APIs for Private NAT Gateways
- Application Examples
- Appendixes
- Out-of-Date APIs
- SDK Reference
Public NAT Gateways
- What Is the Relationship Between a VPC, Public NAT Gateway, EIP Bandwidth, and ECS?
- How Does a Public NAT Gateway Offer High Availability?
- Which Ports Cannot Be Accessed?
- What Are the Differences Between Using a Public NAT Gateway and Using an EIP for an ECS?
- What Should I Do If I Fail to Access the Internet Through a Public NAT Gateway?
- Can I Change the VPC for a Public NAT Gateway?
- Does Public NAT Gateway Support IPv6 Addresses?
- What Security Policies Can I Configure to Implement Access Control If I Use a Public NAT Gateway?
- What Can I Do If Connection Between My Servers and the Internet Fails After I Add SNAT and DNAT Rules?
- Can a Public NAT Gateway Limit the Bandwidth of a Server?
- What Can I Do If the Number of Lost Packets of a Public NAT Gateway Exceeds the Threshold (or EIP Port Allocation Exceeds the Threshold)?
- How Do I Troubleshoot a Network Failure After a Private NAT Gateway Is Configured?
- How Many Private NAT Gateways Can I Buy in a VPC?
- Can I Increase the Numbers of SNAT and DNAT Rules Supported by a Private NAT Gateway?
- Can Private NAT Gateways Translate On-premises IP Addresses Connected to the Cloud Through Direct Connect?
- What Are the Differences Between Private NAT Gateways and Public NAT Gateways?
- Can a Private NAT Gateway Be Used Across Accounts?
SNAT Rules
- Why Do I Need SNAT?
- What Are SNAT Connections?
- What Is the Bandwidth of a Public NAT Gateway That Is Used by Servers to Access the Internet? How Do I Configure the Bandwidth?
- How Do I Resolve Packet Loss or Connection Failure Issues When Using a NAT Gateway?
- What Should I Do If My ECS Fails to Access a Server on the Public Network Through a Public NAT Gateway?
- What Are the Relationships and Differences Between the CIDR Blocks in a NAT Gateway and in an SNAT Rule?
- DNAT Rules
Public NAT Gateways
- Videos
- Glossary
More Documents
- Overview
- Getting Started
- Managing NAT Gateways
- Managing SNAT Rules
- Managing DNAT Rules
- Monitoring Management
- What Is the Relationship Between VPC, NAT Gateway, EIP Bandwidth, and ECS?
- How Does A NAT Gateway Offer High Availability?
- What Can I Do If I Fail to Access the Internet Through the NAT Gateway?
- Can I Change the VPC for a NAT Gateway After It Is Created?
- What Is the Quota of the NAT Gateway?
SNAT
- Why SNAT Is Used?
- What Is the Bandwidth of the NAT Gateway When a Server Accesses the Internet Through the NAT Gateway? Where Can I Configure the Bandwidth?
- DNAT
- Change History
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris Region)
- Overview
Getting Started
- Allowing a Private Network to Access the Internet Using SNAT
- Allowing Internet Users to Access a Service in a Private Network Using DNAT
- Allowing On-Premises Servers to Communicate with the Internet
- Using Private NAT Gateways to Enable Communications Between Cloud and On-premises Networks
- Monitoring
Public NAT Gateways
- What Are the Differences Between Using a NAT Gateway and Using an EIP for an ECS?
- What Should I Do If I Fail to Access the Internet Through a NAT Gateway?
- Can I Change the VPC for a NAT Gateway?
- Can I Update NAT Gateways and SNAT Rules?
- Does NAT Gateway Support IPv6 Addresses?
- What Security Policies Can I Configure to Implement Access Control If I Use a NAT Gateway?
- How Many Private NAT Gateways Can I Create in a VPC?
- Can an SNAT Rule and a DNAT Rule of a Private NAT Gateway Share the Same Transit IP Address?
- Can a Private NAT Gateway Be Used Across ?
SNAT Rules
- What Is the Bandwidth of a NAT Gateway That Is Used by Servers to Access the Internet? How Do I Configure the Bandwidth?
- What Should I Do If My ECS Fails to Access a Server on the Public Network Through a NAT Gateway?
- DNAT Rules
Public NAT Gateways
- Change History
- API Reference (Paris Region)
- Overview
- Getting Started
- NAT Gateway
SNAT
- Why Is SNAT Used?
- DNAT
- Change History
- API Reference (Kuala Lumpur Region)
User Guide (Ankara Region)
- Getting Started
- Monitoring
- SNAT Rules
- DNAT Rules
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- APIs for Public NAT Gateways
- Private Nat API
- Common Parameters
- Change History
Show all
Basic Concepts
EIP
An EIP can be directly accessed over the Internet. A private IP address is an IP address on a local area network (LAN) in the public cloud system and cannot be routed through the Internet.
An EIP is a static, public IP address. You can bind an EIP to an ECS in your subnet to enable the ECS in your VPC to communicate with the Internet through a fixed public IP address.
Each EIP can be used by only one ECS at a time.
SNAT Connections
An SNAT connection consists of the source IP address, source port, destination IP address, destination port, and transmission-layer protocol. The source IP address and source port are the EIP and port translated by SNAT to access the destination IP address and port of a public network. With these five elements, a connection can be distinguished as a unique session.
DNAT Connections
A DNAT connection enables servers in a VPC to share an EIP to provide services accessible from the Internet through IP address mapping or port mapping.
