Configuring Communication Authentication for Storm Processes
The authentication function is disabled by default during the communication of Storm service processes. You can decide whether to enable this function based on the specific service scenario.
Page access: On FusionInsight Manager, choose Cluster > Name of the desired cluster > Services > Storm > Configurations. Click All Configurations. Enter the parameter name in the search box.
Restart the corresponding service after configuration.
Item |
Description |
Default Value |
storm.messaging.netty.authentication |
Indicates whether to enable the Netty communication authentication framework for service processes. Netty communication authentication is disabled by default, but you can enable it for a specific topology. If this parameter is configured on the client, the client configuration prevails. Otherwise, the cluster configuration prevails.
Exercise caution when you enable the Netty communication authentication framework because this will affect the topology throughput. |
false |
