Overview
Log in to FusionInsight Manager and choose Audit. Figure 1 shows the audit information, containing the operation type, security level, start time, end time, user, host name, service, instance, and operation result.
- You can select audit logs at the Critical, Major, Minor, or Notice security level.
- In Advanced Search, you can set filter criteria to query audit logs.
- You can query audit logs by user management, cluster, service, and health in the Operation Type column.
- In the Service column, you can select a service to query corresponding audit logs.
You can select -- to search for audit logs using all other search criteria except services.
- You can query audit logs by operation result, such as, Success, Failed, or Unknown.
- You can click
to manually refresh the current page or click
to modify the columns displayed in the audit table. - Click Export All to export all audit information at a time. You can export the information to a TXT or CSV file.
- For details about the audit content contained in audit management, see Audit Logs.
