Overview of Alarms and Events
Alarms
Log in to FusionInsight Manager and choose O&M > Alarm > Alarms. Figure 1 is displayed. You can view alarm information reported by clusters in FusionInsight Manager, including the alarm name, ID, severity, and generation time. By default, the latest ten alarms are displayed on each page.
Detailed alarm parameters
Click
on the left of a specified alarm to expand the alarm parameters. Table 1 describes the parameters.
Alarm Parameter |
Description |
Alarm ID |
Indicates the alarm ID. |
Alarm Name |
Indicates the alarm information name. |
Alarm Severity |
There are four levels: critical, major, minor, and warning. |
Source |
Cluster name. |
Cleared |
Indicates the time when an alarm is cleared. If the alarm is not cleared, -- is displayed. |
Object |
Indicates the services, processes, or modules that triggers an alarm. |
Automatic Clearance |
The alarm can be automatically cleared after the fault is rectified. |
Alarm Status |
Indicates the status of the alarm. Manually Cleared Indicates the current alarm status, including automatic clearance, manual clearance, and uncleared. |
Generated |
Indicates the time when the alarm is generated |
Alarm Cause |
Indicates the possible cause of an alarm. |
Serial Number |
Indicates the number of alarms generated by the system. |
Additional Information |
Indicates the error information. |
Location |
Indicates the detailed information for locating the alarm, which includes the following:
Manage Alarms:
- Click Export All to export all alarm details.
- If multiple alarms have been handled, you can select one or more alarms to be cleared and click Clear Alarm to clear the alarms in batches. A maximum of 300 alarms can be cleared in each batch.
- Click
to manually refresh the current page. Click
to filter alarms displayed on the page. - You are allowed to filter specified alarms by object or cluster.
- Click Advanced Search. An area where you can search for alarms is displayed. You can search for alarms by alarm ID, alarm name, alarm type, start time, and end time. Click Search to display filtered alarms. After you click Advanced Search again, the number of entered search criteria is displayed.
- You can click Clear, Masking, or Help to perform corresponding operations on an alarm.
- If there are a large number of alarms, you can click View by Category. The system classifies uncleared alarms by alarm ID. After the alarm is classified, click the number of uncleared alarms next to the alarm name to view the alarm details.
Events
Log in to FusionInsight Manager and choose O&M > Alarm > Events. On the displayed page, you can view the information about all events in the cluster, including the alarm name, ID, severity, generation time, object, and location. By default, the latest 10 events are displayed on each page.
Click
on the left of a specified event. The related event parameters are displayed, as shown in Table 2.
Parameter |
Description |
Event ID |
Indicates the event ID. |
Event Name |
Indicates the event name. |
Severity |
Indicates the event severity. There are four levels: Critical, major, minor, and warning. |
Generated |
Indicates the time when an event occurs. |
Object |
Indicates the possible cause of an event. |
Serial Number |
Indicates the number of events generated in the system. |
Location |
Indicates the detailed information for locating the event, which includes the following:
Event Cause |
Source |
Cluster name. |
Manage Events:
- Click Export All to export all event details.
- Click
to filter events displayed on the page. - You are allowed to filter specified events by object or cluster.
- Click Advanced Search. An area where you can search for events is displayed. You can search for events by event ID, severity, event name, start time, and end time.
