On this page
Overview
Overview
Log in to FusionInsight Manager and choose Cluster > Name of the desired cluster > Services.
The service management page containing the function area and service list is displayed.
Figure 1 Service management page
Functional Area
In the function area of the service management page, you can select a view type and filter and search by services. You can use the advanced search function to select required services based on the running status.
Service List
The service list on the service management page contains all installed services in the cluster. If the tile view mode is selected, the services will be displayed in pane style. If you select the list view mode, the services will be displayed in a table.
In this section, the Tile View is used by default.
The service list displays the running status, configuration status, role type, and number of instances of each service. On this page, you can perform some service maintenance tasks, such as starting, stopping, and restarting services.
Table 1 Service running status
Status
Normal
Indicates that the service is running properly.
Faulty
Indicates that the service cannot run properly.
Subhealthy
Indicates that some enhanced functions of the service are abnormal.
Not started
Indicates that the service is stopped.
Unknown
Indicates that the initial status of the service cannot be detected.
Starting
Indicates that the service is being started.
Stopping
Indicates that the service is being stopped.
Failed to start
Indicates that the service fails to be started.
Failed to stop
Indicates that the service fails to be stopped.
  • If the health status of a service is Faulty, an alarm is generated. Rectify the fault based on the alarm information.
  • HBase, Hive, Spark, and Loader may be in the Subhealthy state.
    • If YARN is installed but is abnormal, HBase is in the Subhealthy state. If the multi-instance function is enabled, all installed HBase service instances are in the Subhealthy state.
    • If HBase is installed but is abnormal, Hive, Spark, and Loader are in the Subhealthy state.
    • If any HBase instance is installed but is abnormal after the multi-instance function is enabled, Loader is in the Subhealthy state.
    • If an HBase instance is installed but is abnormal after the multi-instance function is enabled, the Hive and Spark instances that map to the HBase instance are in the Subhealthy state. That is, if HBase 2 is installed but is abnormal, Hive 2 and Spark2 are in the Subhealthy state.
Table 2 Service configuration status
Status
Synchronized
Indicates that all service parameter settings have taken effect in the cluster.
Expired
Indicates that the latest configuration is not synchronized and does not take effect after service parameter settings are modified. The configuration needs to be synchronized and the related services need to be restarted. You can click next to Configuration Status to view expired configuration items.
Failed
Indicates that a communication or read/write exception occurs during the parameter configuration synchronization. Use Synchronize Configuration to rectify the fault.
Synchronizing
Indicates that the service parameter configuration is being synchronized.
Unknown
You can click a service in the service list to perform simple maintenance and management operations on the service, as described in Table 3.
Table 3 Basic management and maintenance
UI Portal
Start Service
Start a specified service in the cluster.
Stop Service
Stop a specified service in the cluster.
Restart Service
Restart a specified service in the cluster.
If a service is restarted, other services that depend on this service will be unavailable. Therefore, select Restart upper-layer services. Determine whether to perform this operation based on the displayed service list. Services are restarted one by one due to their dependency. Table 4 describes the restart duration of a single service.
Service Rolling Restart
Restart a specified service in the cluster without interrupting services. For details about the parameter settings, see Table 1.
  • Enable new configuration parameters for a specified service in the cluster.
  • Deliver new configuration parameters for services whose Configuration Status is Expired.
After some services are synchronized, restart the services for the settings to take effect.
Table 4 Restart time
Service Name
Restart Duration
Start Duration
Remarks
CDL
2min
CDLConnector: 1min
CDLService: 1min
ClickHouse
4min
ClickHouseServer: 2min
ClickHouseBalancer: 2min
HDFS
10min+x
NameNode: 4 min + x
DataNode: 2 min
JournalNode: 2 min
Zkfc: 2 min
X indicates the duration for loading NameNode metadata. About two minutes are required for each ten million files. For example, if there are 50 million files, x indicates 10 minutes. The start duration is affected by the duration for DataNode to report data blocks.
Yarn
5min+x
ResourceManager: 3 min + x
NodeManager: 2 min
x indicates the time corresponding to the number of reserved tasks that need to be restored by ResourceManager. Each 10 thousand reserved tasks require one minute.
MapReduce
2min+x
JobHistoryServer: 2 min + x
x indicates the scanning duration of historical tasks. Each 100 thousand tasks take about 2.5 minutes.
Zookeeper
2min+x
quorumpeer: 2 min + x
x indicates the duration for loading Znodes. Each one million Znodes take about one minute.
Hive
3.5min
HiveServer: 3 min
MetaStore: 90s
WebHcat: 1 min
Hiveoverall service: 3 min
Spark2x
5min
JobHistory2x: 5 min
SparkResource2x: 5 min
JDBCServer2x: 5 min
Flink
4min
FlinkResource: 1 min
FlinkServer: 3min
Kafka
2min+x
Broker: 1 min + x
X indicates the data recovery duration. It takes about two minutes to start a single instance with 20000 partitions.
Storm/Streaming
6min
Nimbus: 3 min
UI: 1 min
Supervisor: 1 min
Logviewer: 1 min
Flume
3min
Flume: 2 min
MonitorServer: 1 min
