Managing the Monitoring Indicator Report
On FusionInsight Manager, you can customize the monitoring items displayed on the Homepage page and export monitoring data.
The time unit of the horizontal axis varies with the custom duration of historical reports. The details are as follows:
- If the custom duration is 0 to 25 hours, the time unit is 5 minutes. In this case, the cluster must have been installed for at least 10 minutes. The system can reserve monitoring data generated in the latest 15 days.
- If the custom duration is 25 to 150 hours, the time unit is 30 minutes. In this case, the cluster must have been installed for at least 30 minutes. The system can reserve monitoring data generated in the latest 3 months.
- If the custom duration is 150 to 300 hours, the time unit is 1 hour. In this case, the cluster must have been installed for at least 1 hour. The system can reserve monitoring data generated in the latest 3 months.
- If the custom duration is 300 hours to 300 days, the time unit is 1 day. In this case, the cluster must have been installed for at least 1 day. The system can reserve monitoring data generated in the latest 6 months.
- If the custom duration is greater than 300 days, the time unit is 7 days. In this case, the cluster must have been installed for at least 7 days. The system can reserve monitoring data generated in the latest 1 year.
- If the disk usage of the GaussDB partition used by the FusionInsight Manager storage exceeds 80%, the real-time monitoring data and monitoring data whose monitoring period is 5 minutes are cleared.
- For Storage Resource (HDFS) in Tenant Resources, if the custom duration is 0 to 300 hours, the time unit is 1 hour. In this case, the cluster must have been installed for at least one hour. The system can reserve monitoring data generated in the latest three months.
Customizing the Monitoring Indicator Report
- Click Homepage.
- In the upper right corner of the chart area, click
and choose Customize from the displayed menu.
The monitoring period is in the unit of five minutes. The monitoring data of the latest one hour is displayed. After the real-time monitoring page is displayed, the real-time monitoring data generated in five minutes is displayed on the right of the monitoring graph.
- In the navigation tree on the left, select a resource subject to be monitored.
- Select one or more monitoring indicators from the monitoring list on the right.
- Click OK.
Exporting Monitoring Data
- Click Homepage.
- In the upper right corner of the chart area of the cluster to be operated, select a time range to obtain monitoring data. For example, 1 Week.
The default setting is real-time monitoring data, which cannot be exported. Click
to customize a time range for the monitoring data to be exported.
and choose Export in the displayed menu.
Exporting the Data of Specified Monitoring Items
- Click Homepage.
- In the upper right corner of any monitoring report pane in the chart area of the cluster to be operated, click
- Select a time range to obtain monitoring data. For example, 1 Week.
By default, real-time monitoring data is selected, which cannot be exported. Click
- Click Export.
