- What's New
- Function Overview
Service Overview
- ELB Infographics
- What Is ELB?
- ELB Advantages
- How ELB Works
- Application Scenarios
- Differences Between Dedicated and Shared Load Balancers
- Load Balancing on a Public or Private Network
- Network Traffic Paths
- Specifications of Dedicated Load Balancers
- Notes and Constraints
- Security
- Permissions
- Product Concepts
- ELB and Other Services
Billing
- Billing Overview
- Billing Mode
- Billing Items (Dedicated Load Balancers)
- Billing Items (Shared Load Balancers)
- Billing Examples
- Bills
- Arrears
- Stopping Billing
- Cost Management
- When Do I Need Public Bandwidth for ELB?
- Will I Be Billed for Both the Bandwidth Used by the Load Balancer and the Bandwidth Used by Backend Servers?
- Do I Need to Adjust the Bandwidth of Shared Load Balancers Based on the Bandwidth Used by Backend Servers?
- Can I Modify the Bandwidth of a Load Balancer?
- What Functions Will Become Unavailable If a Load Balancer Is Frozen?
- Getting Started
User Guide
User Guide for Dedicated Load Balancers
- Using a Dedicated Load Balancer
- Permissions Management
Load Balancer
- Dedicated Load Balancer Overview
- Creating a Dedicated Load Balancer
- Enabling or Disabling Modification Protection for Dedicated Load Balancers
- Modifying the Basic Configurations of a Dedicated Load Balancer
- Modifying the Network Configurations of a Dedicated Load Balancer
- Exporting Dedicated Load Balancers
- Deleting a Dedicated Load Balancer
- Copying a Dedicated Load Balancer
- Enabling or Disabling a Load Balancer
- Listener
- Backend Server Group
- Backend Server
- Health Check
- Security
- Access Logging
- Tags and Quotas
- Cloud Eye Monitoring
- Auditing
User Guide for Shared Load Balancers
Load Balancer
- Shared Load Balancer Overview
- Creating a Shared Load Balancer
- Configuring Modification Protection for Shared Load Balancers
- Changing the Network Configurations of a Shared Load Balancer
- Deleting a Shared Load Balancer
- Enabling or Disabling a Shared Load Balancer
- Enabling Guaranteed Performance for a Shared Load Balancer
- Listener
- Backend Server
- Health Check
- Security
- Access Logging
- Tags and Quotas
- Auditing
- Self-service Troubleshooting
- Appendix
Best Practices
- Using IP as a Backend to Route Traffic Across Backend Servers
- Using Advanced Forwarding for Application Iteration
- Integrating WAF with ELB to Protect Your Websites
- Configuring HTTPS Mutual Authentication to Improve Service Security
- Using ELB to Redirect HTTP Requests to an HTTPS Listener for Higher Service Security
API Reference
- Before You Start
- API Overview
- Selecting an API Version
- Calling APIs
APIs (V3)
- API Version
- Quota
- AZ
- Load Balancer Flavor
- Reserved IP Address
Load Balancer
- Creating a Load Balancer
- Batch Creating Load Balancers
- Upgrading a Load Balancer
- Querying Load Balancers
- Copying a Load Balancer
- Viewing the Details of a Load Balancer
- Updating a Load Balancer
- Deleting a Load Balancer
- Deleting a Load Balancer and Its Associated Resources
- Deleting a Load Balancer and Its Associated Resources (Including EIPs)
- Querying the Status Tree of a Load Balancer
- Deploying a Load Balancer in Other AZs
- Removing a Load Balancer from AZs
- Certificate
- Security Policy
IP Address Group
- Creating an IP Address Group
- Querying IP Address Groups
- Querying the Details of an IP Address Group
- Updating an IP Address Group
- Deleting an IP Address Group
- Updating IP Addresses in an IP Address Group
- Deleting IP Addresses from an IP Address Group
- Querying the Listeners Associated with an IP Address Group
- Listener
- Backend Server
- Health Check
- Forwarding Policy
- Forwarding Rule
- Active/Standby Backend Server Group
- Log
- Asynchronous Task
- Feature Configuration
- Asynchronous Tasks
- APIs (V2)
APIs (OpenStack)
Tag
- Adding a Tag to a Load Balancer
- Batch Adding Load Balancer Tags
- Batch Deleting Load Balancer Tags
- Querying All Tags of a Load Balancer
- Querying the Tags of All Load Balancers
- Querying Load Balancers by Tag
- Deleting a Tag from a Load Balancer
- Adding a Tag to a Listener
- Batch Adding Tags to a Listener
- Batch Deleting Tags from a Listener
- Querying All Tags of a Listener
- Querying the Tags of All Listeners
- Querying Listeners by Tag
- Deleting a Tag from a Listener
- Status Codes
Tag
- Examples
Historical APIs
- Shared Load Balancer APIs (OpenStack) (Discarded)
- Asynchronous Job Query (Discarded)
- Querying Versions (Discarded)
Getting Started
- Obtaining a Token
- Creating a Public Network Load Balancer
- Adding a Listener
- Creating a Backend Server Group
- Adding Backend Servers
- Configuring a Health Check
- Adding a Forwarding Policy
- Adding a Forwarding Rule
- Adding a Whitelist
- Creating an SSL Certificate
- Appendix
- SDK Reference
- Popular Questions
Service Abnormality
- What Can I Do If There Is Packet Loss?
- Why Can't I Access My Backend Servers Through a Load Balancer?
- Why Does a Server Occasionally Time Out When a Client Access It Through Different Load Balancers or Different Listeners of a Load Balancer?
- What Can I Do If ELB Can't Be Accessed or Traffic Routing is Interrupted?
- How Can I Handle Abnormal Status Codes?
- How Do I Handle Abnormal Request Headers?
- How Do I Check for Traffic Inconsistencies?
- Why Does ELB Fail to Distribute Traffic Evenly?
- How Do I Check If There Is Excessive Access Delay?
- What Do I Do If a Load Balancer Fails a Stress Test?
- How Do I Check If Sticky Sessions Failed to Take Effect?
- How Do I Check SSL/TLS Authentication Errors?
Health Checks
- How Do I Troubleshoot an Unhealthy Backend Server of a Dedicated Load Balancer?
- How Do I Troubleshoot an Unhealthy Backend Server of a Shared Load Balancer?
- Why Is the Interval at Which Backend Servers Receive Health Check Packets Different from the Configured Interval?
- How Does ELB Perform UDP Health Checks? What Are the Precautions for UDP Health Checks?
- Why Does ELB Frequently Send Requests to Backend Servers During Health Checks?
- When Does a Health Check Start?
- What Do I Do If a Lot of Access Logs Are Generated During Health Checks?
- What Status Codes Will Be Returned If Backend Servers Are Identified as Healthy?
ELB Functionality
- Can Load Balancers Be Used Separately?
- Can ELB Block DDoS Attacks and Secure Web Code?
- What Types of APIs Does ELB Provide? What Are Permissions of ELB?
- Can Backend Servers of a Load Balancer Run Different OSs?
- Can ELB Be Used Across Accounts or VPCs?
- Can a Backend Server Access Its Load Balancer?
- Can Both the Listener and Backend Server Group Use HTTPS?
- Does ELB Support IPv6 Networks?
- How Do I Determine the Server Response Time Based on Monitoring Data and Logs?
- How Can I Transfer the IP Address of a Client?
- What Are the Differences Between Persistent Connections and Sticky Sessions?
- How Do I Test Sticky Sessions Using Linux Curl Commands?
Load Balancers
- How Does ELB Distribute Traffic?
- How Can I Configure Load Balancing for Containerized Applications?
- Can I Bind Multiple EIPs to a Load Balancer?
- Why Multiple IP Addresses Are Required When I Create a Dedicated Load Balancer?
- Can Backend Servers Access the Internet Using the EIP of the Load Balancer?
- Do Shared Load Balancers Have Specifications?
- What Is the Difference Between the Bandwidth Defined in Each Specification of a Dedicated Load Balancer and the Bandwidth of an EIP?
- How Do I Combine ELB and WAF?
Listeners
- What Are the Relationships Between Load Balancing Algorithms and Sticky Session Types?
- What HTTP Headers Can I Configure for an HTTP and HTTP Listener?
- Will ELB Stop Distributing Traffic Immediately After a Listener Is Deleted?
- Does ELB Have Restrictions on the File Upload Speed and Size?
- Can Multiple Load Balancers Route Requests to One Backend Server?
- How Is WebSocket Used?
- What Are the Three Timeouts of a Listener and What Are the Default Durations?
- Why Can't I Select the Target Backend Server Group When Adding or Modifying a Listener?
- Why Is There a Security Warning After a Certificate Is Configured for an HTTPS Listener?
- Why Is a Forwarding Policy in the Faulty State?
Backend Servers
- Can Backend Servers Access the Internet After They Are Associated with a Load Balancer?
- Can ELB Distribute Traffic Across Servers That Are Not Provided by Huawei Cloud?
- Why Are Backend Servers Frequently Accessed by IP Addresses in 100.125.0.0/16 or 214.0.0.0/8?
- Can ELB Route Traffic Across Regions?
- Does Each Backend Server Need an EIP to Receive Requests from a Public Network Load Balancer?
- How Do I Check the Network Conditions of a Backend Server?
- How Can I Check the Network Configuration of a Backend Server?
- How Do I Check the Status of a Backend Server?
- How Do I Check Whether a Backend Server Can Be Accessed Through an EIP?
- Why Is the Number of Active Connections Monitored by Cloud Eye Different from the Number of Connections Established with the Backend Servers?
- Why Can I Access Backend Servers After a Whitelist Is Configured?
- When Will the Changes to Server Weights Be Applied?
- Certificates
- Access Logging
- Monitoring
Billing
- Videos
- Glossary
More Documents
- Load Balancer
- Listener
- Backend Server
- Health Check
- Certificate
- Access Logging
- Monitoring
- Auditing
- Questions Summary
- ELB Usage
- Load Balancer
- Listener
Backend Server
- Why Is the Interval at Which Backend Servers Receive Health Check Packets Is Different from the Configured Health Check Interval?
- Can Backend Servers Access the Public Network After They Are Associated with a Load Balancer?
- How Can I Check the Network Conditions of a Backend Server?
- How Can I Check the Status of a Backend Server?
- When Is a Backend Server Considered Healthy?
- Health Check
- Obtaining Source IP Addresses
- HTTP/HTTPS Listeners
- Sticky Session
- Appendix
- Change History
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- Load Balancer APIs
- Load Balancer (Enterprise Project) APIs
- Common Parameters
- Appendix
- Change History
User Guide (Paris Region)
Service Overview
- What Is ELB?
- Product Advantages
- How ELB Works
- Quotas and Constraints
- Billing (Shared Load Balancers)
- Billing (Dedicated Load Balancers)
- Permissions
- Product Concepts
- How ELB Works with Other Services
- Getting Started
Load Balancer
- Overview
- Preparations for Creating a Load Balancer
- Configuring Deletion Protection for Load Balancers
- Modifying the Bandwidth
- Changing the Specifications of a Dedicated Load Balancer
- Changing an IP Address
- Binding an IP Address to or Unbinding an IP Address from a Load Balancer
- Adding to or Removing from an IPv6 Shared Bandwidth
- Exporting the Load Balancer List
- Listener
- Advanced Features of HTTP/HTTPS Listeners
- Backend Server (Dedicated Load Balancers)
- Backend Server (Shared Load Balancers)
- Certificate
- Access Control
- TLS Security Policy
- Tag
- Access Logging
- Monitoring
- Auditing
- Load Balancer Migration
- Quotas
FAQ
- Popular Questions
- How Can I Handle Error Codes?
- Can ELB Be Used Separately?
- Does ELB Support Persistent Connections?
- Does ELB Support FTP on Backend Servers?
- Is an EIP Assigned Exclusively to a Load Balancer?
- How Many Load Balancers and Listeners Can I Have?
- Can I Adjust the Number of Backend Servers When a Load Balancer is Running?
- Can Backend Servers Run Different OSs?
- Can I Configure Different Backend Ports for a Load Balancer?
- Can Backend Servers Access the Ports of a Load Balancer?
- Can I Change the VPC and Subnet for My Load Balancer?
- Can I Upgrade a Shared Load Balancer to a Dedicated Load Balancer Without Interrupting Traffic Routing?
- How Do I Check If Traffic Is Being Evenly Distributed?
Load Balancers
- How Can I Access a Load Balancer Across VPCs?
- Why Can't I Delete My Load Balancer?
- Do I Need to Configure EIP Bandwidth for My Load Balancers?
- Why Multiple IP Addresses Are Required When I Create or Enable a Dedicated Load Balancer?
- Why Are Requests from the Same IP Address Routed to Different Backend Servers When the Load Balancing Algorithm Is Source IP Hash?
- Will Traffic Routing Be Interrupted If the Load Balancing Algorithm Is Changed?
- What Is the Difference Between the Bandwidth Included in Each Specification of a Dedicated Load Balancer and the Bandwidth of an EIP?
Listeners
- Can I Bind Multiple Certificates to a Listener?
- Why Cannot I Add a Listener to a Dedicated Load Balancer?
Backend Servers
- Why Is the Interval at Which Backend Servers Receive Health Check Packets Different from What I Have Configured?
- Why Are Backend Servers Frequently Accessed by IP Addresses in 100.125.0.0/16?
- When Will Modified Weights Take Effect?
- Why Must the Subnet Where the Load Balancer Resides Have at Least 16 Available IP Addresses for Enabling IP as a Backend?
Health Checks
- How Do I Troubleshoot an Unhealthy Backend Server?
- Do Maximum Retries Include Health Checks That Consider Backend Servers Unhealthy?
- Which Protocol Should I Select for the Backend Server Group When Adding an HTTPS Listener?
- Why Is There a Security Warning After a Certificate Is Configured?
- Why Can't I Add a Forwarding Policy to a Listener?
- Why Cannot I Select an Existing Backend Server Group When Adding a Forwarding Policy?
- Sticky Sessions
- Certificates
- Monitoring
- Change History
Service Overview
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- Dedicated Load Balancer APIs
- Classic Load Balancer APIs
- Enhanced Load Balancer APIs
- Appendix
- Change History
- Getting Started
Load Balancer
- Overview
- Listener
- Backend Server
- Certificate
- Access Control
- Access Logging
- Monitoring
- Auditing
- Quotas
FAQ
- Popular Questions
- Service Abnormality
ELB Functionality
- Load Balancing Performance
Load Balancers
Listeners
Backend Servers
Health Checks
- Sticky Sessions
- Certificates
- Monitoring
- Change History
- Before You Start
- API Overview
- Calling APIs
- APIs
- Appendix
- Historical APIs
- Change History
User Guide (Ankara Region)
- Load Balancer
- Listener
- Backend Server
- Certificate
- Access Control
- Access Logging
- Monitoring
- Quotas
FAQ
- Popular Questions
ELB Functionality
Load Balancers
Listeners
Backend Servers
Health Checks
- Sticky Sessions
- Certificates
- Monitoring
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- APIs (V3)
- APIs (V2)
APIs (OpenStack)
Tag
- Status Codes
Tag
- Appendix
- Change History
Heavy-Traffic Applications
For an application with heavy traffic, such as a large portal or mobile app store, ELB evenly distributes incoming traffic to multiple backend servers, balancing the load while ensuring steady performance.
Sticky sessions ensure that requests from one client are always forwarded to the same backend server, improving access efficiency.
Applications with Predictable Peaks and Troughs in Traffic
For an application that have predictable peaks and troughs in traffic volumes, ELB works with AS to allow backend servers to be added or removed to keep up with changing demands, improving resource utilization. One example is flash sale, which usually lasts only a few days or even several hours and during which demand on your applications increases rapidly in a short period. By combining ELB with AS, you can always run desired number of backend servers that matches to the load of your application.
Zero SPOFs
ELB routinely performs health checks on backend servers to monitor their healthy state. If a backend server is detected unhealthy, ELB will not route requests to this server until it recovers.
This makes ELB a good choice for services that require high reliability, such as official websites and web services.
Cross-AZ Load Balancing
ELB can distribute traffic across AZs. When an AZ becomes faulty, ELB distributes traffic to backend servers in other AZs.
Banking, policing, and large application systems can use ELB to ensure high availability.
