- What's New
- Getting Started
- User Guide
- What Is DCC?
- How Is a DCC Billed?
- What Steps Will Be Taken by Huawei Cloud to Handle a Server Fault in a DCC?
- How Do I Select a Region?
- How Is the Memory Allocation Rate in a DCC Computing Resource Pool Calculated?
- FAQs About ECSs
- What Are the Characteristics of ECSs in a DeC?
- How Is an ECS in a DeC Billed?
- API Reference
- Glossary
- More Documents
On this page
Show all
Help Center/
Dedicated Computing Cluster/
User Guide (ME-Abu Dhabi Region)/
Overview/
DeC and Other Services
After the DeC service is provisioned for you and you have obtained physical device resources, you can use the following services in the resource area of your DeC:
- Elastic Cloud Server (ECS)
- Image Management Service (IMS)
- Auto Scaling (AS)
- Elastic Volume Service (EVS)
- Volume Backup Service (VBS)
- Object Storage Service (OBS)
- Virtual Private Cloud (VPC)
- Identity and Access Management (IAM)
- Cloud Eye
- Scalable File Service (SFS)
- Cloud Server Backup Service (CSBS)
ECSs you created are running on the physical servers in your DeC.
In your DeC, no further charge is made on the computing resources you request because these resources are the remaining computing resources on the servers you have bought. If the computing resources are insufficient to create new ECSs, you need to expand your DeC.
Parent topic: Overview
