- What's New
- Getting Started
- User Guide
- What Is DCC?
- How Is a DCC Billed?
- What Steps Will Be Taken by Huawei Cloud to Handle a Server Fault in a DCC?
- How Do I Select a Region?
- How Is the Memory Allocation Rate in a DCC Computing Resource Pool Calculated?
- FAQs About ECSs
- What Are the Characteristics of ECSs in a DeC?
- How Is an ECS in a DeC Billed?
- API Reference
- Glossary
- More Documents
Show all
Functions
- Physical isolation
You can exclusively use computing resources in a DeC. ECSs are created in DeCs that are physically isolated from each other.
- Network isolation
Network is logically isolated by using Virtual Private Clouds (VPCs). DeC provides customized network segments for DeC users to configure their networks. Pre-configured security policies are provided, so you can build up a multi-dimensional security protection network with ease.
- Distributed storage
A distributed storage system is used to store instance data.
- Resource management
You can view the total capacity and consumption of computing resources in a DeC and apply for resources as required.
