Deploying a Deployment (Nginx)
You can use images to quickly create a single-pod workload that can be accessed from public networks. This section describes how to use CCE to quickly deploy an Nginx application and manage its lifecycle.
You have created a CCE cluster that contains a node with 4 vCPUs and 8 GiB memory. The node is bound with an EIP.
A cluster is a logical group of cloud servers that run workloads. Each cloud server is a node in the cluster.
For details on how to create a cluster, see Creating a Kubernetes Cluster.
Nginx Overview
Nginx is a lightweight web server. On CCE, you can quickly set up a Nginx web server.
This section uses the Nginx application as an example to describe how to create a workload. The creation takes about 5 minutes.
After Nginx is created, you can access the Nginx web page.
Figure 1 Nginx web page accessed
Creating Nginx on the CCE Console
The following is the procedure for creating a containerized workload from a container image.
  1. Log in to the CCE console.
  2. Click the name of the target cluster to access the cluster console.
  3. In the navigation pane, choose Workloads. In the right pane, click Create Workload in the upper right corner.
  4. Configure the following parameters and retain the default value for other parameters:
    Basic Info
    • Workload Type: Select Deployment.
    • Workload Name: Set it to nginx.
    • Namespace: Select default.
    • Pods: Set the quantity of pods to 1.
    Container Settings
    In the Container Information area, click Basic Info and click Select Image. In the dialog box displayed, click the Open Source Images tab, search for nginx, and select the nginx image.
    Service Settings
    Click the plus sign (+) to create a Service for accessing the workload from an external network. This example shows how to create a LoadBalancer. Configure the following parameters in the window that slides out from the right:
    • Service Name: Enter nginx. The name of the Service is exposed to external networks.
    • Service Type: Select LoadBalancer.
    • Service Affinity: Retain the default value.
    • Load Balancer: If a load balancer is available, select the existing load balancer. If not, select Auto create to create one.
    • Ports:
      • Protocol: Select TCP.
      • Service Port: In this example, set this parameter to 8080. Load balancer will use this port to create a listener to provide an entry for external traffic.
      • Container Port: listening port of the application. In this example, this parameter is set to 80. If another application is used, the container port must be the same as the listening port provided by the application.
  5. Click Create Workload.
    Wait until the workload is created.
    The created Deployment will be displayed on the Deployments tab.
  6. Obtain the external access address of Nginx.
    Click the Nginx workload name to enter its details page. On the page displayed, click the Access Mode tab, view the IP address of Nginx. The public IP address is the external access address.
  7. Enter External access address:Service port in the address box of the browser to access the application. The Service port is configured in Ports.
    Figure 2 Accessing Nginx
