What Is CCE?
Cloud Container Engine (CCE) is a Kubernetes cluster hosting service for enterprises. It manages the entire lifecycle of containerized applications and delivers scalable, high-performance solutions for deploying and managing cloud native applications.
Why CCE?
CCE is a one-stop platform integrating compute (ECS), networking (VPC, EIP, and ELB), storage (EVS, OBS, and SFS), and many other services. Multi-AZ, multi-region disaster recovery (DR) ensures high availability (HA) of Kubernetes clusters.
For more information, see Product Advantages and Application Scenarios.
CCE Cluster Types
There are multiple CCE products.
Category
Subcategory
CCE Standard
CCE Turbo
Positioning
Standard clusters that provide highly reliable and secure containers for commercial use
Next-gen container cluster designed for Cloud Native 2.0, with accelerated computing, networking, and scheduling
Application scenario
For users who expect to use container clusters to manage applications, obtain elastic computing resources, and enable simplified management on computing, network, and storage resources
For users who have higher requirements on performance, resource utilization, and full-scenario coverage
Specification difference
Network model
Cloud native 1.0 networks: for scenarios where requirements on performance are not high and there are not so many containers
  • Tunnel network
  • Virtual Private Cloud (VPC) network
Cloud Native 2.0 networks: for scenarios where requirements on performance are high and there are many containers
Max networking scale: 2,000 nodes
Network performance
The container network is overlaid with the VPC network, causing certain performance loss.
The VPC network and container network are flattened into one for zero performance loss.
Network isolation
  • Tunnel network model: network policies supported for communications within a cluster
  • VPC network model: isolation not supported
Pods can be associated with security groups for isolation. This isolation policy, based on security groups, ensures consistent security isolation both within and outside of a cluster.
Security isolation
cgroups are used to isolate common containers.
  • VM-level isolation is supported for secure containers that run only on physical machines.
  • cgroups are used to isolate common containers.
