Help Center/ Cloud Container Engine/ User Guide (ME-Abu Dhabi Region)/ FAQs/ DNS FAQs/ How Do I Optimize the Configuration If the External Domain Name Resolution Is Slow or Times Out?
The following is an example resolv.conf file for a container in a workload:
In the preceding information:
  • nameserver: IP address of the DNS. Set this parameter to the cluster IP address of CoreDNS.
  • search: domain name search list, which is a common suffix of Kubernetes.
  • ndots: If the number of dots (.) is less than the domain name, search is preferentially used for resolution.
  • timeout: timeout interval.
  • single-request-reopen: indicates that different source ports are used to send different types of requests.
By default, when you create a workload on the CCE console, the preceding parameters are configured as follows:
      dnsConfig:
        options:
          - name: timeout
            value: '2'
          - name: ndots
            value: '5'
          - name: single-request-reopen
These parameters can be optimized or modified based on service requirements.
Scenario 1: Slow External Domain Name Resolution
Optimization Solution
  1. If the workload does not need to access the Kubernetes Service in the cluster, see How Do I Configure a DNS Policy for a Container?
  2. If the number of dots (.) in the domain name used by the working Service to access other Kubernetes Services is less than 2, set ndots to 2.
Scenario 2: External Domain Name Resolution Timeout
  1. Generally, the timeout of a Service must be greater than the value of timeout multiplied by attempts.
  2. If it takes more than 2s to resolve the domain name, you can set timeout to a larger value.
