What Should I Do If a Cluster Is Available But Some Nodes in It Are Unavailable?
If you encountered a fault that a cluster is available but some nodes in it are unavailable, you can rectify this fault by referring to the methods provided in this section.
Mechanism for Detecting Node Unavailability
Kubernetes provides heartbeats to help you detect whether a node is available. For details about the mechanism and detection interval, see Heartbeats.
Fault Locating
The issues here are described in order of how likely they are to occur.
Check these causes one by one until you find the cause of the fault.
- Check Item 1: Whether the Node Is Overloaded
- Check Item 2: Whether the ECS Is Deleted or Faulty
- Check Item 3: Whether the ECS Can Be Logged In To
- Check Item 4: Whether the Security Group Has Been Changed
- Check Item 5: Whether the Security Group Rules Contain the One That Allows the Communication Between the Master Nodes and the Worker Nodes
- Check Item 6: Whether the Disk Is Abnormal
- Check Item 7: Whether Internal Components Are Normal
- Check Item 8: Whether the DNS Address Is Properly Configured
- Check Item 9: Whether the vdb Disk on the Node Has Been Deleted
- Check Item 10: Whether the Docker Service Is Normal
Symptom
The node connection in the cluster is abnormal. Multiple nodes report write errors, but services are not affected.
Fault locating
- Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Nodes. In the right pane, click the Nodes tab, locate the row containing the unavailable node, and click Monitor.
- On the top of the displayed page, click View More to go to the AOM console and view historical monitoring records.
    A too high CPU or memory usage on the node will result in a high network latency or trigger a system OOM, so the node is displayed as unavailable.
Solution
- Reduce the number of workloads on the node by migrating the services to other nodes and configure resource limits for the workloads.
- Clear data on the CCE nodes in the cluster.
- Limit the CPU and memory quotas of each container.
- Add more nodes to the cluster.
- Restart the node on the ECS console.
- Add more nodes and deploy memory-intensive containers separately.
- Reset the nodes.
After the nodes become available, the workload is restored.
- Check whether the cluster is available.
    Log in to the CCE console and check whether the cluster is available. - If the cluster is unavailable, for example, an error occurs, perform operations described in How Do I Locate the Fault When a Cluster Is Unavailable?
- If the cluster is running but some nodes in the cluster are unavailable, go to 2.
- Log in to the ECS console and view the ECS status.
    - If the ECS status is Deleted, go back to the CCE console, delete the corresponding node from the node list, and create another one.
- If the ECS status is Stopped or Frozen, restore the ECS first. It takes about 3 minutes to restore the ECS.
- If the ECS is Faulty, restart the ECS to rectify the fault.
- If the ECS status is Running, log in to the ECS and locate the fault by referring to Check Item 7: Whether Internal Components Are Normal.
- Log in to the ECS console.
- Check whether the node name displayed is the same as that on the VM and whether the password or key can be used to log in to the node.
    If the node names are inconsistent and the node cannot be logged in to using the password or key, it means that a Cloud-Init problem occurred when the ECS was created. In this case, restart the node and submit a service ticket to the ECS personnel to locate the root cause.
Log in to the VPC console. In the navigation pane, choose Access Control > Security Groups and locate the security group of the cluster master node.
The name of this security group is in the format of {Cluster name}-cce-control-{ID}. You can search for the security group by cluster name and then -cce-control-.
Check whether the security group rules have been changed. For details about security groups, see How Can I Configure a Security Group Rule for a Cluster?
Check whether such a security group rule exists.
When a node is added to an existing cluster, if an extended CIDR block is added to the subnet's VPC and the subnet is an extended CIDR block, you need to add the security group rules shown in the below figure to the master node security group, with the name following the format of Cluster name-cce-control-Random number. These rules ensure that the nodes added to the cluster are available. (This step is not required if an extended CIDR block has been added to the VPC during cluster creation.)
Each new node is equipped with a 100-GiB data disk dedicated for Docker. If this data disk is removed or damaged, the Docker service will be disrupted and the node will become unavailable.
Click the node name and check whether the data disk attached to the node has been removed. If the disk has been detached from the node, you need to attach another data disk to the node and restart the node. Then the node can be restored.
- Log in to the ECS of the unavailable node.
- Run the following command to check whether the PaaS components are normal:
    systemctl status kubelet If the command is successfully executed, the status of each component is displayed as active.  If the component status is not active, do as follows: (The faulty component canal is taken as an example): Run systemctl restart canal to restart the component. After restarting the component, run systemctl status canal to check the status.
- If the restart command fails to be run, run the following command to check the running status of the monitrc process:
    ps -ef | grep monitrc If the monitrc process exists, run the following command to kill this process. The monitrc process will be automatically restarted after it is killed. kill -s 9 `ps -ef | grep monitrc | grep -v grep | awk '{print $2}'`
- Log in to the node and check whether any domain name resolution failure is recorded in the /var/log/cloud-init-output.log file.
    cat /var/log/cloud-init-output.log | grep resolv If the command output contains the following information, it means that there is a domain name resolution failure. Could not resolve host: Unknown error
- On the node, ping the domain name that cannot be resolved in the previous step to check whether the domain name can be resolved.
    - If not, the DNS cannot resolve the IP address. Check whether the DNS address in the /etc/resolv.conf file is the same as that configured on the VPC subnet. In most cases, the DNS address in the file is configured incorrectly, leading to the inability to resolve the domain name. To fix this issue, adjust the DNS configuration of the VPC subnet and reset the node.
- If yes, the DNS address configuration is correct. Check whether there are other faults.
If the vdb disk on a node has been deleted, you can refer to this topic to restore the node.
- Run the following command to check whether the Docker service is running:
    systemctl status docker  If the command fails to be executed or the Docker service status is not active, locate the cause or contact technical support if necessary.
- Run the following command to check the number of containers on the node:
    docker ps -a | wc -l If the command is suspended, takes too long to execute, or if there are over 1000 abnormal containers, you should check if workloads are being repeatedly created and deleted. If many containers are being created and deleted frequently, it may result in numerous abnormal containers that cannot be cleared promptly. In this case, stop repeated creation and deletion of workloads or use more nodes to share the load. Typically, the node will be restored after a period of time. If necessary, run the docker rm {container_id} command to manually clear the abnormal containers.
