What Should I Do If a Pod Fails to Pull the Image?
Fault Locating
When a workload enters the state of "Pod not ready: Back-off pulling image "xxxxx", a Kubernetes event of PodsFailed to pull image or Failed to re-pull image will be reported. For details about how to view Kubernetes events, see Viewing Pod Events.
Troubleshooting Process
Determine the cause based on the event information, as listed in Table 1.
Table 1 FailedPullImage
Event Information
Cause and Solution
Failed to pull image "xxx": rpc error: code = Unknown desc = Error response from daemon: Get xxx: denied: You may not login yet
You have not logged in to the image repository.
Check Item 1: Whether imagePullSecret Is Specified When You Use kubectl to Create a Workload
Failed to pull image "nginx:v1.1": rpc error: code = Unknown desc = Error response from daemon: Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io: no such host
The image address is incorrectly configured.
Check Item 2: Whether the Image Address Is Correct When a Third-Party Image Is Used
Check Item 3: Whether an Incorrect Secret Is Used When a Third-Party Image Is Used
Failed create pod sandbox: rpc error: code = Unknown desc = failed to create a sandbox for pod "nginx-6dc48bf8b6-l8xrw": Error response from daemon: mkdir xxxxx: no space left on device
The disk space is insufficient.
Check Item 4: Whether the Node Disk Space Is Insufficient
Failed to pull image "xxx": rpc error: code = Unknown desc = error pulling image configuration: xxx x509: certificate signed by unknown authority
An unknown or insecure certificate is used by the third-party image repository from which the image is pulled.
Check Item 5: Whether the Remote Image Repository Uses an Unknown or Insecure Certificate
Failed to pull image "xxx": rpc error: code = Unknown desc = context canceled
The image size is too large.
Check Item 6: Whether the Image Size Is Too Large
Failed to pull image "docker.io/bitnami/nginx:1.22.0-debian-11-r3": rpc error: code = Unknown desc = Error response from daemon: Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
Check Item 7: Connection to the Image Repository
ERROR: toomanyrequests: Too Many Requests.
Or
you have reached your pull rate limit, you may increase the limit by authenticating an upgrading
The rate is limited because the number of image pull times reaches the upper limit.
Check Item 8: Whether the Number of Public Image Pull Times Reaches the Upper Limit
If the workload status is abnormal and a Kubernetes event is displayed indicating that the pod fails to pull the image, check whether the imagePullSecrets field exists in the YAML file.
Items to Check
  • If an image needs to be pulled from SWR, the name parameter must be set to default-secret.
    apiVersion: extensions/v1beta1
    kind: Deployment
      replicas: 1
      selector:
        matchLabels:
          app: nginx
      strategy:
        type: RollingUpdate
      template:
          labels:
            app: nginx
          containers:
          - image: nginx
            imagePullPolicy: Always
          imagePullSecrets:
          - name: default-secret
  • If an image needs to be pulled from a third-party image repository, the imagePullSecrets parameter must be set to the created secret name.
    When you use kubectl to create a workload from a third-party image, specify the imagePullSecret field, in which name indicates the name of the secret used to pull the image.
CCE allows you to create workloads using images pulled from third-party image repositories.
Enter the third-party image address according to requirements. The format must be ip:port/path/name:version or name:version. If no tag is specified, latest is used by default.
  • For a private repository, enter an image address in the format of ip:port/path/name:version.
  • For an open-source Docker repository, enter an image address in the format of name:version, for example, nginx:latest.
The following information is displayed when you fail to pull an image due to incorrect image address provided.
Solution
You can either edit your YAML file to change the image address or log in to the CCE console to replace the image on the Upgrade tab on the workload details page.
Generally, a third-party image repository can be accessed only after authentication (using your account and password). CCE uses the secret authentication mode to pull images. Therefore, you need to create a secret for an image repository before pulling images from the repository.
Solution
If your secret is incorrect, images will fail to be pulled. In this case, create a new secret.
If the Kubernetes event contains information "no space left on device", there is no disk space left for storing the image. As a result, the image will fail to be pulled. In this case, clear the image or expand the disk space to resolve this issue.
Run the following command to obtain the disk space for storing images on a node:
lvs
Solution 1: Clearing images
Perform the following operations to clear unused images:
  • Nodes that use containerd
    1. Obtain local images on the node.
      crictl images -v
    2. Delete the images that are not required by image ID.
      crictl rmi Image ID
  • Nodes that use Docker
      docker images
      docker rmi Image ID
Do not delete system images such as the cce-pause image. Otherwise, pods may fail to be created.
Solution 2: Expanding the disk capacity
To expand a disk capacity, perform the following steps:
  1. Expand the capacity of a data disk on the EVS console.
    Only the storage capacity of the EVS disk is expanded. You also need to perform the following steps to expand the capacity of the logical volume and file system.
  2. Log in to the CCE console and click the cluster. In the navigation pane, choose Nodes. Click More > Sync Server Data in the row containing the target node.
  3. Log in to the target node.
  4. Run the lsblk command to check the block device information of the node.
    A data disk is divided depending on the container storage Rootfs:
    Overlayfs: No independent thin pool is allocated. Image data is stored in dockersys.
    1. Check the disk and partition sizes of the device.
      # lsblk
      NAME                MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
      vda                   8:0    0   50G  0 disk
      └─vda1                8:1    0   50G  0 part /
      vdb                   8:16   0  200G  0 disk      # Data disk has been expanded but not allocated
      ├─vgpaas-dockersys  253:0    0   90G  0 lvm  /var/lib/containerd          # Space used by the container engine
      └─vgpaas-kubernetes 253:1    0   10G  0 lvm  /mnt/paas/kubernetes/kubelet  # Space used by Kubernetes
    2. Expand the disk capacity.
      Add the new disk capacity to the dockersys logical volume used by the container engine.
      1. Expand the PV capacity so that LVM can identify the new EVS capacity. /dev/vdb specifies the physical volume where dockersys is located.
        pvresize /dev/vdb
        Information similar to the following is displayed:
        Physical volume "/dev/vdb" changed
        1 physical volume(s) resized or updated / 0 physical volume(s) not resized
      2. Expand 100% of the free capacity to the logical volume. vgpaas/dockersys specifies the logical volume used by the container engine.
        lvextend -l+100%FREE -n vgpaas/dockersys
        Size of logical volume vgpaas/dockersys changed from <90.00 GiB (23039 extents) to <190.00 GiB (48639 extents).
        Logical volume vgpaas/dockersys successfully resized.
      3. Adjust the size of the file system. /dev/vgpaas/dockersys specifies the file system path of the container engine.
        resize2fs /dev/vgpaas/dockersys
        Filesystem at /dev/vgpaas/dockersys is mounted on /var/lib/containerd; on-line resizing required
        old_desc_blocks = 12, new_desc_blocks = 24
        The filesystem on /dev/vgpaas/dockersys is now 49807360 (4k) blocks long.
When a pod pulls an image from a third-party image repository that uses an unknown or insecure certificate, the image fails to be pulled from the node. The pod event list contains the event "Failed to pull the image" with the cause "x509: certificate signed by unknown authority".
The security of EulerOS 2.9 images is enhanced. Some insecure or expired certificates are removed from the system. It is normal that this error is reported in EulerOS 2.9 but not or some third-party images on other types of nodes. You can also perform the following operations to rectify the fault.
Solution
  1. Check the IP address and port number of the third-party image server for which the error message "unknown authority" is displayed.
    You can see the IP address and port number of the third-party image server for which the error is reported in the event information "Failed to pull image".
    Failed to pull image "bitnami/redis-cluster:latest": rpc error: code = Unknown desc = error pulling image configuration: Get https://production.cloudflare.docker.com/registry-v2/docker/registry/v2/blobs/sha256/e8/e83853f03a2e792614e7c1e6de75d63e2d6d633b4e7c39b9d700792ee50f7b56/data?verify=1636972064-AQbl5RActnudDZV%2F3EShZwnqOe8%3D: x509: certificate signed by unknown authority
    The IP address of the third-party image server is production.cloudflare.docker.com, and the default HTTPS port number is 443.
  2. Load the root certificate of the third-party image server to the node where the third-party image is to be downloaded.
    Run the following commands on the EulerOS and CentOS nodes with {server_url}:{server_port} replaced with the IP address and port number obtained in Step 1, for example, production.cloudflare.docker.com:443:
    If the container engine of the node is containerd, replace systemctl restart docker with systemctl restart containerd.
    openssl s_client -showcerts -connect {server_url}:{server_port} < /dev/null | sed -ne '/-BEGIN CERTIFICATE-/,/-END CERTIFICATE-/p' > /etc/pki/ca-trust/source/anchors/tmp_ca.crt
    update-ca-trust
    Run the following command on Ubuntu nodes:
    openssl s_client -showcerts -connect {server_url}:{server_port} < /dev/null | sed -ne '/-BEGIN CERTIFICATE-/,/-END CERTIFICATE-/p' > /usr/local/share/ca-certificates/tmp_ca.crt
    update-ca-trust
The pod event list contains the event "Failed to pull image". This may be caused by a large image size.
Failed to pull image "XXX": rpc error: code = Unknown desc = context canceled
However, the image can be manually pulled by running the docker pull command.
Possible Causes
In Kubernetes clusters, there is a default timeout period for pulling images. If the image pulling progress is not updated within a certain period of time, the download will be canceled. If the node performance is poor or the image size is too large, the image may fail to be pulled and the workload may fail to be started.
Solution
  • Solution 1 (recommended):
    1. Log in to the node and manually pull the image.
      • containerd nodes:
        crictl pull <image-address>
      • Docker nodes:
        docker pull <image-address>
    2. When creating a workload, ensure that imagePullPolicy is set to IfNotPresent (the default configuration). In this case, the workload uses the image that has been pulled to the local host.
  • Solution 2 (applies to clusters of v1.25 or later): Modify the configuration parameters of the node pools. The configuration parameters for nodes in the DefaultPool node pool cannot be modified.
    1. Log in to the CCE console.
    2. Click the cluster name to access the cluster console. Choose Nodes in the navigation pane and click the Node Pools tab.
    3. Locate the row that contains the target node pool and click Manage.
    4. In the window that slides out from the right, modify the image-pull-progress-timeout parameter under Docker/containerd. This parameter specifies the timeout interval for pulling an image.
    5. Click OK.
Symptom
The following error message is displayed during workload creation:
Possible Causes
Failed to connect to the image repository due to the disconnected network. SWR allows you to pull images only from the official Docker repository. For image pulls from other repositories, you need to access the Internet.
Solution
  • Bind a public IP address to the node which needs to pull the images.
  • Upload the image to SWR and then pull the image from SWR.
Symptom
Or
you have reached your pull rate limit, you may increase the limit by authenticating an upgrading: https://www.docker.com/increase-rate-limits.
Possible Causes
Docker Hub sets the maximum number of container image pull requests. For details, see Docker Hub pull usage and limits.
Solution
Push the frequently used image to SWR and then pull the image from SWR.
