Help Center/
      Cloud Container Engine/
        User Guide (ME-Abu Dhabi Region)/
        FAQs/
        Workload/
        Workload Exception Troubleshooting/
      What Should I Do If a Workload Is Stopped Caused by Pod Deletion?
Symptom
A workload is in Stopped state.
Possible Cause
The metadata.enable field in the YAML file of the workload is false. As a result, the pod of the workload is deleted and the workload is in the stopped status.
Solution
Delete the enable field or set it to true.
   Parent topic: Workload Exception Troubleshooting
