Recommended GPU Driver Versions for CCE
This section describes the recommended driver versions for CCE clusters. If you use a non-recommended GPU driver version, make sure to check its compatibility with the model and OS. Select a proper NVIDIA driver version by checking the compatibility list for CUDA Toolkit and NVIDIA drivers based on the version used by your application.
Supported GPU Drivers
- The list of supported GPU drivers applies only to CCE AI Suite (NVIDIA GPU) of v1.2.28 or later.
- To use the latest GPU driver, upgrade your CCE AI Suite (NVIDIA GPU) to the latest version.
GPU Model |
Supported Cluster Type |
Specification |
OS |
HCE OS 2.0 |
Ubuntu 22.04.5 |
Ubuntu 22.04.4 |
Ubuntu 22.04.3 |
CentOS Linux release 7.6 |
Tesla T4 |
CCE standard cluster |
g6 pi2 |
535.216.03 535.54.03 510.47.03 470.57.02 |
535.216.03 535.161.08 |
535.216.03 535.161.08 535.54.03 470.141.03 |
Tesla V100 |
p2s p2vs p2v |
