cce-hpa-controller Limitations
Check Items
Check whether there are compatibility limitations between the current and target cce-controller-hpa add-on versions.
Solution
There are compatibility limitations between the current and target versions of the cce-controller-hpa add-on. To address this, install an add-on that provides metrics APIs, like metrics-server, in the cluster.
Install the metrics add-on in the cluster and try again.
