Help Center/
Cloud Container Engine/
User Guide (ME-Abu Dhabi Region)/
Clusters/
Upgrading a Cluster/
Troubleshooting for Pre-upgrade Check Exceptions/
Upgrade Management
Upgrade Management
Check Items
Check whether the target cluster is under upgrade management.
Solution
CCE may temporarily restrict the cluster upgrade due to the following reasons:
- The cluster is identified as the core production cluster.
- Other O&M tasks are either in progress or planned, such as the 3-AZ reconstruction on master nodes.
- If the cluster contains Docker nodes but their OSs are different from that of the node pool, reset these nodes and run the pre-upgrade check again.
To resolve this issue, contact technical support based on logs displayed on the console.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
