Help Center/ Cloud Backup and Recovery/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Optimization/ What Are Common Problems During Cloud-Init Installation?
Updated on 2024-02-04 GMT+08:00
You are advised to install Cloud-Init after the restoration to ensure the new server restored by using backups support custom configurations.
To install Cloud-Init, see section "Installing Cloud-Init" in the Image Management Service User Guide.
To configure Cloud-Init, see section "Configuring Cloud-Init" in the Image Management Service User Guide.
This section illustrates the FAQs encountered when installing Cloud-Init and their solutions.
Ubuntu 16.04/CentOS 7: Failed to Set Cloud-Init Automatic Start
  • Symptom
    After Cloud-Init is installed, run the following command to set Cloud-Init automatic start:
    systemctl enable cloud-init-local.service cloud-init.service cloud-config.service cloud-final.service
    Information similar to the following is displayed:
    Figure 1 Failed to set Cloud-Init automatic start
  • Solution
    1. Run the following command:
      systemctl unmask cloud-init-local.service cloud-init.service cloud-config.service cloud-final.service
    2. Run the following commands to set automatic start again:
    3. Run the following commands to check the Cloud-Init status:
      systemctl status cloud-init-local.service cloud-init.service cloud-config.service cloud-final.service
      As shown in the following figures, failed is displayed and all services are in the inactive state.
      This is because the address that the system uses to access Cloud-Init is redirected to /usr/bin/, but the actual installation path is /usr/local/bin.
      Figure 2 Checking Cloud-Init status
      Figure 3 Checking Cloud-Init status
    4. Run the cp /usr/local/cloud-init /usr/bin/ command to copy the cloud-init file to the usr/bin directory, and then run the following command to restart Cloud-Init:
      # systemctl restart cloud-init-local.service cloud-init.service cloud-config.service cloud-final.service
      Figure 4 Restarting Cloud-Init
    5. Run the following commands to check the Cloud-Init status:
Ubuntu14.04: chkconfig and systemctl Not Installed
  • Symptom
    chkconfig is not installed.
  • Solution
    Run the following commands to install chkconfig:
    # apt-get update
    # apt-get install sysv-rc-conf
    # cp /usr/sbin/sysv-rc-conf /usr/sbin/chkconfig
    After the installation completes, run the following command to query the Cloud-Init version:
    cloud-init -v
    -bash:/usr/bin/cloud-init:not found this command
    Solution: Run the following command to copy the cloud-init file to the usr/bin directory:
    # cp /usr/local/bin/cloud-init /usr/bin/
Debian 9.5: Failed to Query the Cloud-Init Version and Set Automatic Start
  1. After Cloud-Init is installed, run the following command to query its version:
    cloud-init -v
    Solution: Run the # cp /usr/local/bin/cloud-init /usr/bin/ command to copy the cloud-init file to the usr/bin directory.
  2. Run the cloud-init init --local command.
    Figure 5 Information returned when Cloud-Init automatic start is successfully set
    Cause analysis: The compilation fails because the GNU compiler collection (GCC) is not installed.
    Solution
    After GCC is installed, run the following command to install Cloud-Init:
    yum -y install gcc
  3. After Cloud-Init is installed, run the following command to set Cloud-Init automatic start:
    Figure 6 Failed to set Cloud-Init automatic start
    Solution
      # systemctl unmask cloud-init-local.service cloud-init.service cloud-config.service cloud-final.service
      # systemctl enable cloud-init-local.service cloud-init.service cloud-config.service cloud-final.service
    3. Run the following command to restart Cloud-Init:
      Run the systemctl status command to check the Cloud-Init status. Information similar to the following is displayed:
      Figure 7 Checking the Cloud-Init status
CentOS 7/Fedora 28: Required C Compiler Not Installed
  • Symptom
    After Cloud-Init is installed, run the following command:
    The following information is displayed:
    /usr/lib/python2.5/site-packages/Cheetah/Compiler.py:1532: UserWarning:
    You don't have the C version of NameMapper installed! I'm disabling Cheetah's useStackFrames option as it is painfully slow with the Python version of NameMapper. You should get a copy of Cheetah with the compiled C version of NameMapper.
      "\nYou don't have the C version of NameMapper installed!
  • Possible Cause
    This alarm is generated because the C version of NameMapper needs to be compiled when installing Cloud-Init. However, GCC is not installed in the system, and the compilation cannot be performed. As a result, the C version of NameMapper is missing.
  • Solution
    Run the following command to install GCC:
    yum -y install gcc
    Reinstall Cloud-Init.
CentOS 7/Fedora: Failed to Use the New Password to Log In to the Server Created from a Backup After Cloud-Init Is Successfully Installed
  • Symptom
    After Cloud-Init is installed, the new password cannot be used to start the new server. After logging in to the server using the old password, you find the NIC is not started.
    Figure 8 NIC not started
  • Solution
    Log in to the server, open the DHCP configuration file /etc/sysconfig/network-scripts/ifcfg-ethX, and comment out HWADDR.
