Updated on 2024-02-04 GMT+08:00
Backup
- Do I Need to Stop the Server Before Performing a Backup?
- Can I Back Up a Server Deployed with Databases?
- How Can I Distinguish Automatic Backups From Manual Backups?
- Can I Choose to Back Up Only Some Partitions of a Disk?
- Does CBR Support Cross-Region Backup?
- Can I Back Up Two Disks to One Target Disk?
- How Do I Replicate a Disk to the Same AZ in a Region as the Source Disk?
- Will the Server Performance Be Affected If I Delete Its Backups?
- Can I Use Its Backup for Restoration After a Resource Is Deleted?
- How Many Backups Can I Create for a Resource?
- Can I Use an Incremental Backup to Restore Data After a Full Backup Is Deleted?
- Can I Stop an Ongoing Backup Task?
- How Do I Reduce the Vault Space Occupied by Backups?
- How Do I View the Size of Each Backup?
- How Do I View My Backup Data?
- How Long Will My Backups Be Kept?
Parent topic: FAQs
