Creating an SFS Turbo Backup Vault
This section describes how to create an SFS Turbo backup vault.
- Log in to the CBR console.
- In the upper left corner, click
and select a region. - Click
and choose Storage > Cloud Backup and Recovery > SFS Turbo Backups.
- In the upper right corner of the page, click Create SFS Turbo Backup Vault.
- Select a protection type.
- Backup: An SFS Turbo backup vault stores SFS Turbo backups.
- (Optional) In the file system list, select the file systems to be backed up. After file systems are selected, they are added to the list of selected file systems.
- The selected file systems must have not been associated with any vault and must be in the Available state.
- You can also associate file systems with the vault you are creating later if you skip this step.
- Specify the vault capacity. This capacity is the total size of the file systems that you want to associate with this vault. Plan the vault capacity and ensure that it is at least the same as the size of the file systems you want to back up. If a backup policy is applied to the vault, plan more capacity as required. The capacity ranges from 10 GB to 10,485,760 GB.
You can expand the vault capacity if it becomes insufficient.
- Configure auto backup.
- If you select Configure, you must then select an existing backup policy or create a policy. After the vault is created, CBR will apply the policy to this vault, and all file systems associated with this vault will be automatically backed up based on this policy.
- If you select Skip, file systems associated with this vault will not be automatically backed up until you apply a backup policy to the vault.
- If you have subscribed to the EPS service, add the vault to an existing enterprise project.
EPS provides a unified method to manage cloud resources by project, allowing you to manage resources, users, and user groups in your projects. The default enterprise project is default.
- (Optional) Add tags to the vault.
Tags are key-value pairs, which are used to identify, classify, and search for vaults. You can add a maximum of 10 tags for a vault, and vault tags are only used for vault search and management.
Table 1 describes the parameters of a tag.Table 1 Tag parameter description Parameter
Example Value
Key
Each tag has a unique key. You can specify a key or select the key of an existing tag created in TMS.
A tag key:
- Can contain 1 to 36 Unicode characters.
- Can contain only letters, digits, hyphens (-), and underscores (_).
Key_0001
Value
A tag value can be repetitive or left blank.
A tag value:
- Can contain 0 to 43 Unicode characters.
Value_0001
- Specify a name for the vault.
The name can contain 1 to 64 characters. Only letters, digits, underscores (_), or hyphens (-) are allowed. Example: vault-612c
You can also use the default name vault_xxxx.
- Complete the creation as prompted.
- Go back to the SFS Turbo Backups page. You can see the created vault in the vault list.
You can associate file systems to the new vault or perform backup for the file systems. For details, see Vault Management.
