SDKs
APIG supports API authentication based on IAM, apps, and custom authorizers. You can also choose not to authenticate API requests. For details about the differences between the four modes and how to select one, see Calling APIs. This section describes how to download SDKs and view related instructions.
SDKs are used when you call APIs through app authentication. Download SDKs and related documentation and then call APIs by following the instructions in the documentation.
- Go to the APIG console.
- In the navigation pane, choose Help Center.
- Click Using SDKs.
 - Click Download SDK next to the desired language. An SDK contains SDK code and sample code. SDKs vary depending on the language.
To view the support guide, click SDK Documentation.
