Removing Image Metadata
To protect privacy, you can remove metadata such as GPS location, shooting device information, and watermarks from images. You can edit code on OBS Console or make an API call to remove metadata from an image.
For details about how to use image styles, see Step 3: Creating an Image Style and Processing the Image.
The following operation is used to remove image metadata.
This operation is represented by strip.
Example of Removing Image Metadata
Remove image metadata.
https://hw-image-demo.obs.ap-southeast-1.myhuaweicloud.com/example.jpg?x-image-process=image/strip
Helpful Links
- For image processing FAQs, see Image Processing FAQs.
- For more image processing operations (such as cropping and watermarking), see Image Processing.
