Changing Image Quality
You can edit code on OBS Console or make an API call to change the quality of a JPG or WebP image.
To save space, you can compress JPG images. Table 1 describes the parameters.
This operation is represented by quality.
Parameter |
Value Description |
Code Example |
q |
Relative quality of the image. The image is compressed to q% of the original. The value ranges from 1 to 100. Formula for compression: Target quality = Original quality × q% For example, if the original image quality is 100% and the relative quality is 80%, then the target image quality is 80%. If the original quality is 80% and the relative quality is 80%, then the target quality is 64%. |
image/resize,w_100,h_100/quality,q_80 |
Q |
Absolute quality of the image. The image is compressed into Q%. Q is irrelevant to and does not depend on the original image. The value ranges from 1 to 100. Formulas for compression:
For example, if the original image quality is 100% and the absolute quality is 80%, then the target image quality is 80%. If the original quality is 70% and the absolute quality is 80%, then the target quality is 70%. |
- q is valid only for JPG images.
- If both q and Q are used, the output is based on Q.
Examples
- Resize the image by setting the height and width both to 100 and generate a JPG image with a relative quality of 80%.
- Resize the image by setting the height and width both to 100 and generate a JPG image with an absolute quality of 80%.
