Help Center/ Object Storage Service/ User Guide/ Data Processing/ Image Processing/ Converting Formats and Interlacing Images
Updated on 2025-11-10 GMT+08:00
Converting Formats
You can use the GUI or code mode on OBS Console or make an API call to convert images to different formats:
  • Supported original formats: JPG, JPEG, PNG, BMP, WebP, GIF, and TIFF
  • Supported target formats: JPG, PNG, BMP, and WebP (described in Table 1)
This operation is represented by format.
Table 1 Format conversion
Value Description
Code Example
jpg
The image is saved in JPG format. If the original image is in vector format such as WebP, BMP, or PNG, the transparent part will be padded to white.
image/format,jpg
webp
The image is saved in WebP format.
image/format,webp
bmp
The image is saved in BMP format.
image/format,bmp
png
The image is saved in PNG format.
image/format,png
Interlaced Image Loading
You can edit code on OBS Console or make an API call to load images in an interlaced way.
With format conversion, images are generated in baseline JPEG format by default. If you want to generate an image in progressive JPEG, use the interlace parameter. Table 2 describes the parameters.
  • Display of baseline JPG images: from top to bottom
  • Display of progressive JPEG images: from blurry to clearer and clearer
This operation is represented by interlace.
Table 2 Interlaced loading
Value Description
Code Example
value
The value can be 0 or 1.
0: The output is a JPG image that is displayed from top to bottom.
1: The output is a JPEG image in an interlaced display.
image/format,jpg/interlace,1
