Slimming Images
You can edit code on OBS Console or make an API call to slim images.
Slimming is a simplified image compression, which generates images with an absolute quality of 75%. You do not need to configure any parameter. You can slim images just by running a command.
This operation is represented by imageslim.
- Only JPG images can be slimmed.
- It is recommended that you slim images after other image processing operations.
Example
Resize an image by setting the width and height both to 100 and then slim the resized image.
- Original image: https://hw-image-demo.obs.ap-southeast-1.myhuaweicloud.com/example.jpg
- Resize the image by setting the width and height both to 100 using the code image/resize,w_100,h_100.
- Slim the image using the code imageslim.
Resizing and slimming
