Updated on 2026-11-24 GMT+08:00
Using Image Processing with APIs
Image processing provides OBS REST APIs that you can use to process images stored in OBS. You can easily resize, crop, compress, and perform other operations on images and quickly obtain the processed images. This feature is suitable for a wide range of use cases, including e-commerce, social networking, and mobile services.
How It Works
OBS image processing uses extended parameters in object access URLs. When a client requests an object, it includes processing instructions in the x-image-process parameter. The OBS server decodes, transforms, and encodes the original image in real time and directly returns the processed image without modifying the original object. Image processing is synchronous and performed in real time. The processing time for a single request increases with the image size, resolution, and number of commands in the pipeline.
For details about the constraints on image processing operations, images, and commands, see Notes and Constraints.
API Authentication
  • If an image allows anonymous access, you can access it in a web browser using an image processing request without a signature.
  • If an image does not allow anonymous access, the image processing request must include a signature. For details about how to calculate a signature and construct a signed URL, see Using a Pre-Signed URL.
Process
OBS provides REST APIs. In the REST architectural style, the network is viewed as a set of resources. Resources on the network are identified by Uniform Resource Identifiers (URIs), and client applications locate resources using Uniform Resource Locators (URLs). The URL is in the https://Endpoint/uri format. By putting a URL that complies with the command rules of image processing in a browser, you can get the new image after processing.
Figure 1 shows the flowchart of using image processing with REST APIs.
REST is an HTTP-based architectural style. REST APIs conform to REST constraints. They use resource URIs to identify objects and methods such as GET, PUT, POST, and DELETE to perform operations on the objects. Requests are stateless, and responses can be cached for reuse to improve efficiency.
Figure 1 Flowchart of using image processing with REST APIs
Creating an Account and Enabling OBS
Before using image processing, you must have a cloud service account and enable OBS. Once OBS is enabled, image processing is available for use. To use OBS properly, make sure that you have sufficient account balance or you have a valid payment method. If you have already enabled OBS and you can use it properly, skip this section.
  1. Visit the Huawei Cloud official website.
  2. Click Sign Up in the upper right corner.
  3. Complete the account creation as instructed.
    After the creation is complete, you will be navigated to your information page.
  4. Create an OBS bucket, so that you can use image processing properly.
Uploading an image
You can upload images using OBS Console, OBS Browser+, or REST APIs.
For details, see Upload Overview.
Skip this section if the image to be processed already exists in your bucket.
If you want to use a user-defined domain name for image processing, you need to grant anonymous users the read permission for the image. For more information, see Granting All Accounts the Read Permission for Certain Objects.
Processing the Image
This section describes how to build a URL for processing images using REST APIs. Once you have enabled OBS successfully, you can call REST APIs to process images simply by putting a URL that complies with the command rules of image processing in a browser.
URL Composition
A URL consists of the OBS domain name, bucket name, the original image name, and processing command or style name.
Access with Commands
URL format: https://bucketName.endpoint/objectName?x-image-process=image/commands
  • endpoint represents the endpoint address of the region where the bucket is located. You can obtain the endpoint from the bucket's basic information. For more information, see Regions and Endpoints.
  • bucketName represents the name of the bucket that accommodates the image to be processed on OBS.
  • objectName represents the name of the original image stored in the bucketName bucket. The name suffix must be supported by image processing.
  • commands represents the processing commands. Three types of delimiters can be used between commands or command parameters. If no commands are specified, the original image will be returned.
Example URL: https://hw-image-demo.obs.ap-southeast-1.myhuaweicloud.com/example.jpg?x-image-process=image/crop,x_100,y_50
  • Delimiters
Delimiters are used to separate one field from another in the commands in a URL. For details, see Table 1.
Table 1 Delimiters
Name
Character
Sequence
Parameter delimiter
_
Fixed
Delimiter between a parameter and its value
Command delimiter
Irrelevant
Delimiter between command parameters
Pipe delimiter
Relevant
Delimiter between two processing commands. See Pipes.
  • Pipes
If an image needs to be processed multiple times, for example, cropped and then resized, separate each group of operation commands with a pipe delimiter (/). The commands are executed sequentially from left to right. The format is as follows: https://image-demo.obs.region.example.com/example.jpg?x-image-process=image/resize,w_100,h_100/quality,q_80.
For example, https://image-demo.obs.ap-southeast-1.myhuaweicloud.com/example.jpg?x-image-process=image/resize,w_100,h_100/quality,q_80 are two pipes executed from left to right. The output of the left command becomes the input of the right command.
Access with a Style Name
URL format: https://bucketName.endpoint/objectName?x-image-process=style/stylename
  • bucketName is the bucket name on OBS.
  • stylename is the name of an existing style in the bucketName bucket on OBS Console. At present, REST APIs cannot be used to perform operations related to styles, such as creating, changing, or deleting styles.
Example URL: https://image-demo.obs.obs.ap-southeast-1.myhuaweicloud.com/example.jpg?x-image-process=style/stylename
Helpful Links
For image processing FAQs, see Image Processing FAQs.
