Using Image Processing on OBS Console
To resize, compress, or watermark images in an OBS bucket in batches, you can create an image processing style on the image processing page of OBS Console by using buttons or editing code. You can then preview the the effect of applying the style to an image on the Preview Image tab of the image's details page. You can also click Copy Link to get the URL of the styled image.
Process
You can use OBS Console, OBS SDKs, or REST APIs to process images. Figure 1 shows the flowchart of using image processing on OBS Console.
Step 1: Signing Up for an Account
Before using image processing, you must have a cloud service account and enable OBS. Once OBS is enabled, image processing is available for use. To use OBS properly, make sure that you have sufficient account balance or you have a valid payment method. If you have already enabled OBS and you can use it properly, skip this section.
- Visit the Huawei Cloud official website.
- Sign up for an account. Before using OBS, you must create a Huawei Cloud account. If you already have one, start from Step 2: Uploading an Image.
- In the bucket list of OBS Console, click the desired bucket to go to the Objects page.
- Click Upload Object to open the Upload Object dialog box.
- Click add files marked by the red box in Figure 2 to open the local file browser.
- Select the image that you want to upload and click Open.
- Click Upload.
Step 3: Creating an Image Style
Each image style specifies a set of processing operations, including cropping, compression, and adding watermarks. For multiple images that require the same processing operations in a bucket, you can create an image style to apply it to the images.
When creating a style, you can preview the style effect of the sample image on the right in real time. Image processing encodes and decodes images, so the preview image size differs from the actual size.
When using REST APIs to access image processing, you can call the style name in the URL to avoid entering complex commands. For details about the domain name rules for API access, see Access with a Style Name.
You can create up to 100 styles for a bucket.
You can also replicate existing image processing styles from another bucket.
If you are an IAM user, before creating an image style, make sure that programmatic access has been enabled for yourself. For details, see Viewing or Modifying IAM User Information.
- Log in to OBS Console.
- Click a desired bucket name. In the navigation pane, choose Data Processing > Image Processing. Figure 3 Image processing
- Click Create to go to the style editing page shown in Figure 4.
- On the editing page, specify a style name and configure properties:
- Style Name
Enter an easy-to-remember style name. Only letters (uppercase or lowercase), digits, periods (.), underscores (_), and hyphens (-) are allowed. The style name contains 1 to 256 characters, for example, rotate_0001.
- Edit Mode
Choose either GUI or Code to create an image style by configuring parameters or by editing code.
An example code is as follows:
image/resize,m_lfit,h_400,w_400,limit_1
- Other settings
Configure the image effect, resizing, watermark, and output.
- Style Name
- Click OK to save the style. The new style will be displayed in the style list.
Replicating Image Styles
You can replicate an existing image style to quickly create a new one.
- Click Replicate.
- Select a replication source, which is the source bucket where the required image styles were configured.
- The image styles replicated from a source bucket do not overwrite existing styles in the destination bucket. Any styles that conflict with existing ones are not replicated.
- The version of both the source and destination buckets must be 3.0.
- You can remove the styles that you do not want to replicate.
Figure 5 Replicating image styles
- Click OK to replicate the image styles to the current bucket.
Step 4: Using the Image Style
You can use existing image styles in a bucket in either of the following ways:
- Copying a link (see Copying a Link): On an image's details page of OBS Console, you can copy a link for accessing the image with a style applied on the Preview Image tab page. By pasting the copied link in a browser, you can get the new image.
- Editing a domain name: You can edit a domain name by referring to the format given below and open it in a browser to have the image with the style applied.
<Image link>?x-image-process=style/<Style name>
Image link can be obtained from the image details page. For details, see Editing a Domain Name. Style name is the one defined when the style was created. A style name can contain only uppercase or lowercase letters, digits, periods (.), underscores (_), and hyphens (-) and is 1 to 256 characters long, for example, rotate_0001.
Copying a Link
- Click the name of the bucket that contains the desired styles to go to the Objects page.
- Click the name of an existing image or of a newly uploaded image to go to its details page.
- Click the Preview Image tab to preview the image effect in one or more styles.
Figure 6 Preview Image
- Click Copy Link in the style card you want. If Copied successfully. is prompted, you have got the link for accessing the image with the style applied.
- On the OBS object list page, click an image to be processed to go to its details page.
- Choose Object ACL > User Access > Anonymous User and click Edit. In the displayed dialog box, grant the object read permission to anonymous users and click OK. For details, see Figure 7.
- Click the icon
next to Link to copy the image link. - Add ?x-image-process=style/<Style name> to the end of the copied link and open the new link in a browser. Then, you can access the image with the style applied.
Link example:
https://bucketname.obs.ap-southeast-1.myhuaweicloud.com/example.jpg?x-image-process=style/stylename
The links and style names above are for reference only. Change them accordingly in practice.
