Enabling Guaranteed Performance for a Shared Load Balancer
Guaranteed performance allows shared load balancers to handle up to 50,000 concurrent connections, 5,000 new connections per second, and 5,000 queries per second. It provides you with more stable and reliable load balancing capabilities in case of traffic surge.
If your shared load balancers were created after February 10, 2023, guaranteed performance will be enabled for them by default.
If your shared load balancers were created before February 10, 2023, perform the following operations to enable guaranteed performance.
Notes
- Guaranteed performance cannot be disabled once enabled.
- After guaranteed performance is enabled, shared load balancers will be billed on a pay-per-use basis. For details about product prices, see Product Pricing Details.
- In the upper left corner of the page, click and select the desired region and project.
- Click in the upper left corner to display Service List and choose Networking > Elastic Load Balance.
- Locate the target shared load balancer and click its name to enter the Summary page.
- Click Enable.
- Click Enable Now.
Figure 1 Enabling guaranteed performance
