- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Before You Start
- Permissions Management
Exclusive ServiceComb Engine
- Creating a ServiceComb Engine
Managing ServiceComb Engines
- Viewing ServiceComb Engine Information
- Obtaining the Service Center Address of a ServiceComb Engine
- Obtaining the Configuration Center Address of a ServiceComb Engine
- Viewing the Instance Quota of a ServiceComb Engine
- Viewing the Configuration Item Quota of a ServiceComb Engine
- Configuring Backup and Restoration of a ServiceComb Engine
- Managing Public Network Access for a ServiceComb Engine
- Viewing ServiceComb Engine Operation Logs
- Upgrading a ServiceComb Engine Version
- Deleting a ServiceComb Engine
- Changing ServiceComb Engine Specifications
- Managing Security Authentication for a ServiceComb Engine
- Managing Tags
- Using ServiceComb Engines
- Registry/Configuration Center
- Key Operations Recorded by CTS
Best Practices
- CSE Best Practices
ServiceComb Engines
ServiceComb Engine Application Hosting
- Hosting Spring Cloud Applications Using Spring Cloud Huawei SDK
- Hosting a Java Chassis Application
- Registry/Configuration Centers
Developer Guide
- Overview
- Developing Microservice Applications
- Preparing the Environment
- Connecting Microservice Applications
- Deploying Microservice Applications
- Using ServiceComb Engine Functions
- Appendix
API Reference
- Before You Start
- API Overview
- Calling APIs
- Examples
CSE API
- API Calling
- Dynamic Configuration
Engine Management
- Querying Flavors Supported by a Microservice Engine
- Querying the Microservice Engine List
- Creating an Exclusive Microservice Engine
- Querying Details About a Microservice Engine
- Deleting a Microservice Engine
- Querying Details About a Microservice Engine Job
- Retrying an Exclusive ServiceComb Engine
- Upgrading an Exclusive ServiceComb Engine
- Changing Microservice Engine Specifications
- Updating the Configuration of an Exclusive Microservice Engine
Microservice Governance
- Querying the Governance Policy List
- Creating a Dark Launch Policy
- Querying a Dark Launch Rule of a Microservice
- Deleting a Dark Launch Policy
- Changing a Governance Policy
- Deleting a Governance Policy
- Querying Governance Policy Details
- Creating a Governance Policy
- Querying the Governance Policy List of a Specified Kind
- Nacos API
ServiceComb API
- API Calling
- Authentication
Microservice
- Querying Information About a Microservice
- Deleting Definition Information About a Microservice
- Querying Information About All Microservices
- Creating Static Information for a Microservice
- Deleting Static Information About Microservices in Batches
- Modifying Extended Attributes of a Microservice
- Querying the Unique Service or Schema ID of a Microservice
- Schema
Microservice Instance
- Registering a Microservice Instance
- Querying a Microservice Instance Based on service_id
- Deregistering a Microservice Instance
- Querying Details About a Microservice Instance
- Modifying the Extended Information About a Microservice Instance
- Modifying Status of a Microservice Instance
- Sending Heartbeat Information
- Querying a Microservice Instance by Filter Criteria
- Querying Microservice Instances in Batches
- Dependency
- Configuration Management
- Appendixes
- Change History
- SDK Reference
- Precautions When Using Huawei Cloud CSE
- Nacos Engines
ServiceComb Engines
- How Do I Perform Local Development and Testing?
- How Can I Handle a Certificate Loading Error?
- What If the Header Name Is Invalid?
- What Is the Performance Loss of Mesher?
- Why Is "Version validate failed" Displayed When I Attempt to Connect to the Service Center?
- Why Is "Not enough quota" Displayed When I Attempt to Connect to the Service Center?
- What Should I Do If the Service Registration Fails After IPv6 Is Enabled for the Exclusive ServiceComb Engine with Security Authentication Enabled?
- What Is Service Name Duplication Check?
- Why Do I Have to Define Service Contracts?
- Why Are Microservice Development Framework and Netty Versions Unmatched?
- What Do I Need to Know Before Upgrading an Exclusive ServiceComb Engine?
- What Must I Check Before Migrating Services from the Professional to the Exclusive Microservice Engine?
- Why Is "Duplicate cluster name" Displayed?
- Error Message "the subnet could not be found" Is Displayed When the Access Address Fails to Be Processed During Engine Creation
- Why Is Error "does not match rule: {Max: 100, Regexp: ^[a-zA-Z0-9]{1,160}$|^[a-zA-Z0-9][a-zA-Z0-9_\-.]{0,158}[a-zA-Z0-9]$}"}" Reported?
- What Should I Do If SpringCloud Applications Fail to Connect to the Configuration Center of ServiceComb Engine 2.x?
- Why Could My the Global Configuration Not Be Modified?
- Obtain Configurations Failed
- Videos
On this page
Help Center/
Cloud Service Engine/
User Guide/
Exclusive ServiceComb Engine/
Managing ServiceComb Engines/
Specifications of exclusive ServiceComb engines can be automatically changed online. The specifications can only be increased. The service will be disconnected intermittently during the change, which does not affect services. New services cannot be registered during the change.
- Log in to CSE.
- Choose Exclusive ServiceComb Engines.
- Click More > Change Specifications in the Operation column of the target engine. Alternatively, click the target engine and click Change Specifications in the ServiceComb Engine Information area.
- On the displayed page, select the target specifications.
- Click Change Now, confirm the information, and click Submit.
Parent topic: Managing ServiceComb Engines
