- What's New
- Getting Started
- User Guide
Best Practices
- Using a Custom Script to Implement Consistent Backup for MySQL
- Using a Custom Script to Implement Consistent Backup for SAP HANA
- Using a Custom Script to Implement Consistent Backup for Other Linux Applications
- Troubleshooting a Custom Script Error
- Verifying the Application-Consistent Backup Result (Linux)
- Verifying the Application-Consistent Backup Result (Windows)
- Protecting SQL Server in Failover Cluster Mode
- Protecting SQL Server in Always on Availability Groups Mode
- Change History
- API Reference
About Concepts
- What Is CSBS?
- What Are Full Backup and Incremental Backup?
- What Is Consistent Backup?
- What Are the Differences Between CSBS and VBS?
- What Is a Backup Policy?
- What Are the Differences Between Backup and Disaster Recovery?
- What Are the Differences Between Backup and Snapshot?
- Why Is the Disk Space Usage Displayed in the File System Different from the Backup Size?
About Pricing
- How Is CSBS Billed?
- How Do Yearly/Monthly Resource Packages Function When I Have Bought More Than One?
- Are CSBS and VBS Resource Packages Interoperable Between CSBS and VBS?
- Why Am I Charged in Pay-per-use Mode Although I Have Purchased Resource Package?
- What Exactly Are the Function Package and the Storage Package?
- Will the CSBS Backups Displayed on the VBS Page Be Charged Repeatedly?
- How Do I Query CSBS Pay-Per-Use Billing Details?
- Why Is the Fee Deducted After a Backup Is Deleted?
- How Do I Disable CSBS?
- How Do I Stop CSBS from Charging?
About Backup
- Does CSBS Support Backing Up All EVS Disks on an ECS?
- Do I Need to Stop the ECS Before Backing It Up?
- Can an ECS with Application Systems Be Backed Up?
- What Are the Minimum Backup Frequency and Maximum Number of Retained Backups Supported by CSBS?
- How Can I Distinguish Automatic Backups From Manual Backups?
- How Can I Configure a Backup Policy?
- Can I Choose to Back Up Only Some Partitions of a Disk?
- Does CSBS Support Cross-Region Backup for ECSs?
- Which Types of Databases Can Be Backed Up Using Database Server Backup?
- How Do I Select Among Database Server Backup, Cloud Server Backup, and Disk Backup?
- How Do I Migrate ECS Data Across Regions Using CSBS?
- Which Time Zone Is the Automatic Backup Time Based On?
- What Can I Do If a Backup Cannot Be Deleted?
- About Restoration
- Others
About Concepts
- Troubleshooting
- Videos
- Glossary
More Documents
User Guide (Paris and Amsterdam Regions)
- Getting Started
- Management Operations
- About Concepts
About Backup
- About Restoration
- Others
- Troubleshooting Cases
- Change History
- API Reference (Paris and Amsterdam Regions)
Changing the Password of the Account for Reporting Alarms (SNMP v3)
To enhance O&M security, you are advised to change the password of the account for reporting alarms.
- You have obtained a username and its password for logging in to the management console.
- The username and password for logging in to a server have been obtained.
Context
This section introduces the procedures in Windows and Linux.
If the authentication password and data encryption password for SNMP v3 of the Agent is the same, security risks exist. To ensure system security, you are advised to set the authentication password and data encryption password to be different ones.
The initial authentication password is BCM@DataProtect6 and the initial data encryption password is BCM@DataProtect8.
The password must meet the following complexity requirements:
- Contains 8 to 16 characters.
- Contains at least one of the following special characters: `~!@#$%^&*()-_=+\|[{}];:'",<.>/?
- Contains at least two of the following types of characters:
- Uppercase letters
- Lowercase letters
- Digits
- Cannot be the same as the username or the username in reverse order.
- Cannot be the same as the old passwords.
- Cannot contain spaces.
Procedure (Windows)
- Log in to the server where the Agent is installed.
- Open the CLI and go to the installation path\bin directory.
- Run the agentcli.exe chgsnmp command. Type the login password of the Agent and press Enter.
Please choose operation: 1: Change authentication password 2: Change private password 3: Change authentication protocol 4: Change private protocol 5: Change security name 6: Change security Level 7: Change security model 8: Change context engine ID 9: Change context name Other: Quit Please choose:
admin is the username configured during the Agent installation.
- Select the SN of the authorization password or data encryption password that you want to change and press Enter.
- Type the old password and press Enter.
- Type a new password and press Enter.
- Type the new password again and press Enter. The password is changed.
Procedure (Linux)
- Log in to the Linux server using the server password.
- Run the TMOUT=0 command to prevent PuTTY from exiting due to session timeout.
After the preceding command is executed, the system remains running even when no operation is performed, which results in security risks. For security purposes, run the exit command to exit the system after you finish performing operations.
- Run the su - rdadmin command to switch to user rdadmin.
- Run the /home/rdadmin/Agent/bin/agentcli chgsnmp command. Type the login password of the Agent and press Enter.
The installation path of the Agent is /home/rdadmin/Agent.
