- What's New
- Getting Started
- User Guide
Best Practices
- Using a Custom Script to Implement Consistent Backup for MySQL
- Using a Custom Script to Implement Consistent Backup for SAP HANA
- Using a Custom Script to Implement Consistent Backup for Other Linux Applications
- Troubleshooting a Custom Script Error
- Verifying the Application-Consistent Backup Result (Linux)
- Verifying the Application-Consistent Backup Result (Windows)
- Protecting SQL Server in Failover Cluster Mode
- Protecting SQL Server in Always on Availability Groups Mode
- Change History
- API Reference
About Concepts
- What Is CSBS?
- What Are Full Backup and Incremental Backup?
- What Is Consistent Backup?
- What Are the Differences Between CSBS and VBS?
- What Is a Backup Policy?
- What Are the Differences Between Backup and Disaster Recovery?
- What Are the Differences Between Backup and Snapshot?
- Why Is the Disk Space Usage Displayed in the File System Different from the Backup Size?
About Pricing
- How Is CSBS Billed?
- How Do Yearly/Monthly Resource Packages Function When I Have Bought More Than One?
- Are CSBS and VBS Resource Packages Interoperable Between CSBS and VBS?
- Why Am I Charged in Pay-per-use Mode Although I Have Purchased Resource Package?
- What Exactly Are the Function Package and the Storage Package?
- Will the CSBS Backups Displayed on the VBS Page Be Charged Repeatedly?
- How Do I Query CSBS Pay-Per-Use Billing Details?
- Why Is the Fee Deducted After a Backup Is Deleted?
- How Do I Disable CSBS?
- How Do I Stop CSBS from Charging?
About Backup
- Does CSBS Support Backing Up All EVS Disks on an ECS?
- Do I Need to Stop the ECS Before Backing It Up?
- Can an ECS with Application Systems Be Backed Up?
- What Are the Minimum Backup Frequency and Maximum Number of Retained Backups Supported by CSBS?
- How Can I Distinguish Automatic Backups From Manual Backups?
- How Can I Configure a Backup Policy?
- Can I Choose to Back Up Only Some Partitions of a Disk?
- Does CSBS Support Cross-Region Backup for ECSs?
- Which Types of Databases Can Be Backed Up Using Database Server Backup?
- How Do I Select Among Database Server Backup, Cloud Server Backup, and Disk Backup?
- How Do I Migrate ECS Data Across Regions Using CSBS?
- Which Time Zone Is the Automatic Backup Time Based On?
- What Can I Do If a Backup Cannot Be Deleted?
- About Restoration
- Others
About Concepts
- Troubleshooting
- Videos
- Glossary
More Documents
User Guide (Paris and Amsterdam Regions)
- Getting Started
- Management Operations
- About Concepts
About Backup
- About Restoration
- Others
- Troubleshooting Cases
- Change History
- API Reference (Paris and Amsterdam Regions)
Show all
Using Backups to Create Images
CSBS allows you to create images using ECS backups. You can use the images to provision ECSs for fast restoring the service running environment.
- The following operations have been performed before you use an ECS's backup to create an image:
- You have optimized the Linux ECS (referring to (Optional) Optimizing a Linux Private Image) and installed Cloud-Init (referring to Installing Cloud-Init).
- You have optimized the Windows ECS (referring to (Optional) Optimizing a Windows Private Image) and installed Cloudbase-Init (referring to Installing Cloudbase-Init).
- The backup you want to use to create an image meets either of the following two conditions:
- The backup is in the Available state.
- The backup is in the Creating state which is marked with Image can be created.
Once a backup creation starts, the backup enters the Creating state. After a while, a message stating "Image can be created" is displayed under Creating. In this case, the backup can be used for creating an image, even though it is still being created and cannot be used for restoration.
- The backup you want to use to create an image contains the system disk data.
- Images created from a backup are the same, so CSBS allows you to use a backup to create only one full-ECS image that contains the whole data of the ECS's system disk and data disks, in order to save the image quota. After an image is created, you can use the image to provision multiple ECSs in a batch.
- A backup with an image created cannot be deleted manually or automatically. If you want to delete such a backup, delete its image first. If a backup is automatically generated based on a backup policy and the backup has been used to create an image, the backup will not be counted as a retained backup and will not be deleted automatically.
- Log in to the CSBS management console.
- Under Storage > Cloud Server Backup Service.
- Click the Backups tab and locate the desired server backup. For details, see Viewing a Backup.
- In the row of the backup, click Create Image.
- Create an image by referring to Creating a Full-ECS Image Using a CSBS Backup.
- If you want to use an image to provision ECSs, see Creating ECSs Using an Image.
