Discarded Kubernetes APIs
Check Items
![](https://support.huaweicloud.com/intl/en-us/usermanual-cce/public_sys-resources/note_3.0-en-us.png)
Due to the limited time range of audit logs, this check item is only an auxiliary method. APIs to be deprecated may have been used in the cluster, but their usage is not included in the audit logs of the past day. Check the API usage carefully.
Solution
Check Description
Based on the check result, it is detected that your cluster calls a deprecated API of the target cluster version using kubectl or other applications. You can rectify the fault before the upgrade. Otherwise, the API will be intercepted by kube-apiserver after the upgrade.
There are no version compatibility differences when v1.27 is upgraded to v1.28.
