Help Center>
Cloud Container Engine>
User Guide>
User Guide for Autopilot Clusters>
Clusters>
Upgrading a Cluster>
Troubleshooting for Pre-upgrade Check Exceptions>
SSH Connectivity of Master Nodes
Updated on 2024-06-26 GMT+08:00
Check Items
Check whether CCE can connect to your master nodes.
Solution
Contact technical support.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
