Updated on 2024-08-16 GMT+08:00
CCE Autopilot Cluster Version Release Notes
Indexes
v1.28
Table 1 Release notes for the v1.28 patch
CCE Cluster Patch Version
Kubernetes Version
Feature Update
Enhancement
Vulnerability Fixing
v1.28.4-r0
v1.28.3
  • Custom metrics, such as network and disk metrics, can be used create HPA policies.
  • kube-apiserver can be accessed from a public network.
When YAML is used to create an application, the parameters that are not supported by CCE Autopilot and do not affect functionality were automatically ignored.
Fixed some security issues.
v1.28.3-r0
v1.28.3
  • Supported automatic cluster upgrade.
  • Hosted the Everest storage add-on at the backend.
  • Supported OBS volumes.
v1.28.2-r0
v1.28.3
  • Supported CronHPA policies.
  • Supported the security context configuration for pods.
v1.28.1-r10
v1.28.3
Supported cluster v1.28. For more information, see Kubernetes 1.28 Release Notes.
v1.27
Table 2 Release notes for the v1.27 patch
Kubernetes Version
Feature Update
Enhancement
v1.27.6-r0
v1.27.4
v1.27.5-r0
v1.27.4
v1.27.4-r0
v1.27.4
v1.27.3-r30
v1.27.4
Supported one-click configuration of monitoring alarms.
v1.27.3-r20
v1.27.4
  • Supported the Nginx Ingress Controller add-on.
  • Supported the Cloud Native Cluster Monitoring and Cloud Native Logging add-ons to monitor application metrics and collect application logs.
  • Launched the application template market.
  • Supported CustomResourceDefinitions (CRDs).
  • Interconnected with CloudShell.
Optimized the function of creating a NAT gateway by default during cluster creation so that applications can access the public network.
v1.27.3-r10
v1.27.4
Supported cluster v1.27. For more information, see Kubernetes 1.27 Release Notes.
