Updated on 2026-08-03 GMT+08:00
Kubernetes 1.35 Release Notes
CCE Autopilot has passed the Certified Kubernetes Conformance Program and is a certified Kubernetes offering. CCE Autopilot now supports Kubernetes 1.35 cluster features. This section describes the changes made in Kubernetes 1.35.
New and Enhanced Features
  • Support managedBy field for Jobs (GA)
    In Kubernetes 1.35, the support for the managedBy field for Jobs graduates to GA. This feature introduces the .spec.managedBy field for Jobs. You can use this field to allow an external controller (such as Kueue or MultiKueue) to take full responsibility for the synchronization logic and status update of a Job. For details, see Job Managed By Goes GA.
  • Pod Generation (GA)
    In Kubernetes 1.35, Pod Generation graduates to GA. This feature leverages metadata.generation that automatically increments the value when the pod spec is updated. Additionally, the status.observedGeneration field is added, which is reported by kubelet to identify the observed pod configuration version. For details, see Pod Generation.
  • Node Topology Downward API (beta)
    In Kubernetes 1.35, Node Topology Downward API graduates to Beta. This feature uses the built-in PodTopologyLabels admission controller to synchronize standard topology labels of nodes to pods. Containers can directly obtain topology information such as regions, AZs, and host names through the downward API without requiring privileged init containers. For details, see Node Topology Labels via Downward API.
  • Storage Version Migrator in-tree (beta)
    In Kubernetes 1.35, this feature graduates to beta. This feature moves the Storage Version Migrator (SVM) from an external component to kube-controller-manager, providing a standard StorageVersionMigration API. For details, see Move Storage Version Migrator in-tree.
  • Mutable CSINode Allocatable (beta)
    In Kubernetes 1.35, this feature graduates to beta. This feature allows dynamic modification of the CSINode.Spec.Drivers[*].Allocatable.Count field. When volume mounting fails due to insufficient capacity, the capacity information is automatically corrected to prevent the scheduler from suspending pods based on outdated data. For details, see Mutable CSINode Allocatable Property.
  • StatefulSet maxUnavailable (beta)
    In Kubernetes 1.35, this feature graduates to beta. The maxUnavailable field is added to the StatefulSet rolling update policies to specify the maximum number of unavailable pods during an update (either as a number or a percentage). For details, see Implement maxUnavailable in StatefulSet.
  • KYAML (beta)
    In Kubernetes 1.35, KYAML graduates to beta. The KYAML output format (-o kyaml), compatible with the standard YAML parsers, is added to kubectl. For details, see Introducing KYAML, a safer, less ambiguous YAML subset/encoding.
  • Configurable HPA tolerance (beta)
    In Kubernetes 1.35, this feature graduates to beta. This feature adds the tolerance configuration item to the native HPA scaling policies. For details, see Configurable tolerance for HPA.
  • Container Restart Rules (beta)
    In Kubernetes 1.35, this feature graduates to beta. This feature adds the restartPolicy and restartPolicyRules configurations for containers. These configurations can override the pod-level restart policy. For details, see Container Restart Rules.
  • CSI driver service account tokens via secrets field (beta)
    In Kubernetes 1.35, the serviceAccountTokenInSecrets field in the CSI driver spec can be set to true. This enables service account tokens to be passed through a dedicated Secrets field of the CSI request instead of the volume_context field, preventing sensitive token leakage. For details, see CSI driver opt-in for service account tokens via secrets field.
  • Consider Terminating pods in Deployments (beta)
    In Kubernetes 1.35, this feature graduates to beta. The .status.terminatingReplicas field is added for Deployments and ReplicaSets to count the number of terminating pods. For details, see Consider Terminating Pods in Deployments.
API Changes and Removals
  • In Kubernetes 1.35 and later versions, cgroup v1 is marked as deprecated and is not supported by default. CCE Autopilot clusters v1.35 are compatible with the OSs of cgroup v1 nodes.
  • In Kubernetes 1.35, ObservedGeneration is added to the conditions field of CustomResourceDefinition.
  • In Kubernetes 1.35, the StorageVersionMigration v1beta1 API is added and the v1alpha1 API is removed. Before an upgrade, all v1alpha1 resources must be deleted.
  • In Kubernetes 1.35, the kuberc configuration architecture is updated, and two optional configuration fields, credPluginPolicy and credPluginAllowlist, are added.
  • In Kubernetes 1.35, the core DRA feature gate is enabled by default and cannot be disabled.
  • In Kubernetes 1.35, kubectl get -o kyaml is enabled by default. You can set KUBECTL_KYAML to false to disable this behavior.
  • In Kubernetes 1.35, the status.terminatingReplicas statistics feature for ReplicaSets and Deployments has been upgraded to beta and is enabled by default.
    In Kubernetes 1.35, the JobManagedBy feature has been upgraded to GA. The feature gate is locked to be true and will be removed in later versions.
Enhanced Kubernetes 1.35 on CCE
During a version maintenance period, CCE periodically updates Kubernetes 1.35 with enhanced functions.
For details about cluster version updates, see Patch Versions.
References
For more details about the performance comparison and functional evolution between Kubernetes 1.35 and other versions, see Kubernetes 1.35 Release Notes.
