Updated on 2026-09-15 GMT+08:00
CCE Autopilot Cluster Events
CCE Autopilot can report a range of events to AOM when a cluster is running. You can add event alarms as needed to monitor the health of cluster data plane and control plane components. This helps you quickly identify and resolve problems, ensuring cluster stability and reliability.
Data Plane Events
Table 1 Workload events
Object
Event Name
Severity
Pod
PodOOMKilling
Major
Check whether the pod exits due to OOM.
This event is reported by CCE Node Problem Detector (1.18.41 or later) and Cloud Native Log Collection (1.3.2 or later).
Pod
FailedStart
Major
Check whether the pod has started.
Pod
FailedPullImage
Major
Check whether the pod has pulled an image.
Pod
BackOffStart
Major
Check whether the pod fails to restart.
Pod
FailedScheduling
Major
Check whether the pod has been scheduled.
Pod
BackOffPullImage
Major
Check whether the pod has pulled an image after a retry.
Pod
FailedCreate
Major
Check whether the pod has been created.
Pod
Unhealthy
Minor
Check whether the pod health check is successful.
Pod
FailedDelete
Minor
Check whether the workload has been deleted.
Pod
ErrImageNeverPull
Minor
Check whether the workload has pulled an image.
Pod
FailedScaleOut
Minor
Check whether replicas can be added to scale the workload.
Pod
FailedReconfig
Minor
Check whether the pod configuration has been updated.
Pod
FailedActive
Minor
Check whether the pod is activated.
Pod
FailedRollback
Minor
Check whether the pod is rolled back.
Pod
FailedUpdate
Minor
Check whether the pod is updated.
Pod
FailedScaleIn
Minor
Check whether the pod scale-in failed.
Pod
FailedRestart
Minor
Check whether the pod is restarted.
Deployment
SelectorOverlap
Minor
Check whether label selectors in the cluster conflict.
Deployment
ReplicaSetCreateError
Minor
Check whether a workload ReplicaSet can be created.
Deployment
DeploymentRollbackRevisionNotFound
Minor
Check whether the Deployment rollback version is available.
Job
TooManyActivePods
Minor
Check whether there are still active pods after the number of pods in a job reaches the preset value.
Job
TooManySucceededPods
Minor
Check whether there are extra running pods after the number of pods in a job reaches the preset value.
CronJob
FailedGet
Minor
Check whether the CronJob can be queried.
CronJob
FailedList
Minor
Check whether the list of pods can be obtained.
CronJob
UnexpectedJob
Minor
Check whether there are any unknown CronJobs.
Table 2 Network events
Object
Event Name
Severity
Service
CreatingLoadBalancerFailed
Minor
Check whether a load balancer has been created.
Service
DeletingLoadBalancerFailed
Minor
Check whether the load balancer has been deleted.
Service
UpdateLoadBalancerFailed
Minor
Check whether the load balancer has been updated.
Table 3 Storage events
Object
Event Name
Severity
PV
DetachVolumeFailed
Minor
Check whether the block storage is mounted.
PV
VolumeUnknownReclaimPolicy
Minor
Check whether a volume reclaim policy is specified.
PV
SetUpAtVolumeFailed
Minor
Check whether the volume is mounted.
PV
VolumeFailedRecycle
Minor
Check whether the volume is reclaimed.
PV
WaitForAttachVolumeFailed
Minor
Check whether the block storage is mounted to the node.
PV
VolumeFailedDelete
Minor
Check whether the volume is deleted.
PV
MountDeviceFailed
Minor
Check whether the device is mounted.
PV
TearDownAtVolumeFailed
Minor
Check whether the volume is unmounted.
PV
UnmountDeviceFailed
Minor
Check whether the device is unmounted.
PV
AttachVolumeFailed
Minor
Check whether the block storage is demounted from the node.
PVC
VolumeResizeFailed
Minor
Check whether the volume capacity is expanded.
PVC
ClaimLost
Minor
Check whether the PVC is normal.
PVC
ProvisioningFailed
Minor
Check whether the volume is created.
PVC
ProvisioningCleanupFailed
Minor
Check whether the volume has been cleared.
PVC
ClaimMisbound
Minor
Check whether the PVC is bound to an incorrect volume.
Table 4 Auto scaling events
Object
Event Name
Severity
HPA
InvalidTargetRange
Major
  • Invalid extendedhpa.metrics is configured in annotations of HPA.
  • The metric type in spec of HPA is incorrect.
HPA
FailedGetScale
Major
HPA failed to obtain the resource object to be scaled.
HPA
FailedComputeMetricsReplicas
Major
An error occurs when the number of replicas to be adjusted for resources is calculated. For example, metric-server is unavailable, resource metric collection fails, or the CPU usage is incorrectly set.
You can run the following command to view details:
kubectl describe horizontalpodautoscaler <hpa-name>
HPA
FailedGetObjectMetric
Major
Failed to obtain the metrics of the specified object (such as PVC and ConfigMap).
HPA
FailedGetPodsMetric
Major
Failed to obtain pod resource metrics (resource usages of a pod).
HPA
FailedGetResourceMetric
Major
Failed to obtain cluster resource metrics (resource usages of a cluster).
HPA
FailedGetContainerResourceMetric
Major
Failed to obtain the resource metrics of a container.
HPA
FailedGetExternalMetric
Major
Failed to obtain external metrics.
HPA
FailedRescale
Major
Failed to update the desired number of copies of the resource object to be scaled.
HPA
SuccessfulRescale
Minor
The desired number of copies of the resource object to be scaled is updated.
CronHPA
ScaleFailed
Major
CronHPA failed to update the desired number of copies of the resource object to be scaled.
CronHPA
FailedGetHorizontalPodAutoscaler
Major
CronHPA failed to query the associated HPA object. (Generally, kube-apiserver cannot respond.)
CronHPA
FailedGetHpaScale
Major
CronHPA failed to obtain the resource object to be scaled.
CronHPA
UpdateHPAFailed
Major
CronHPA failed to update the associated HPA object.
CronHPA
UpdateHPASuccess
Minor
CronHPA successfully updates the associated HPA object.
CronHPA
SkipUpdateHPA
Minor
CronHPA skips updating the associated HPA object.
CronHPA
SkipUpdateTarget
Minor
CronHPA skips updating the number of copies of the resource object to be scaled.
CronHPA
UpdateTargetSuccess
Minor
CronHPA successfully updates the number of copies of the resource object to be scaled.
Control Plane Events
Table 5 Control plane events
Event ID
Severity
Internal error
Major
Check whether there is an internal error in the cluster.
Failed to check component status or components are abnormal
Major
Check whether the statuses of cluster components can be obtained or the components malfunction.
Cluster status is Unavailable
Major
Check whether the cluster is available.
Cluster status is Error
Major
Check whether the cluster is faulty.
Cluster status is not updated for a long time
Major
Check whether the cluster is stuck in a state for a long period.
Failed to update cluster status
Major
Check whether the cluster status is updated.
Failed to delete the unavailable connection of the Kubernetes cluster
Major
Check whether unavailable Kubernetes connections have been deleted.
Failed to sync the cluster cert
Major
Check whether the cluster certificates have been synchronized.
