Help Center/ Cloud Container Engine_Autopilot/ User Guide/ Network/ Ingresses/ Comparison Between LoadBalancer Ingresses and Nginx Ingresses
Updated on 2025-04-21 GMT+08:00
CCE Autopilot clusters can use either an Nginx Ingress or LoadBalancer Ingress to enable Layer-7 network access for applications.
  • An Nginx Ingress, enhanced by CCE Autopilot using NGINX Ingress Controller from the community, updates community features and bug fixes regularly. Nginx Ingresses provide various configuration options, catering to users with advanced gateway customization requirements.
  • A LoadBalancer Ingress, backed by ELB, offers fully managed and O&M-free services. It can handle tens of millions of concurrent connections and millions of new connections. LoadBalancer Ingresses support both shared and dedicated load balancers.
The following tables describe the differences between Nginx Ingresses and LoadBalancer Ingresses.
Typical Application Scenarios
Type
Nginx Ingress
  • Standard configurations
  • Extensive gateway customization
  • Canary release and blue-green deployment of cloud native applications
  • Fully managed, highly available gateway, and no O&M required
  • Layer 7 high-performance auto scaling of cloud native applications
  • Isolated resources for dedicated use. A load balancer deployed in a single AZ can handle up to 20 million concurrent connections, making it ideal for managing a large volume of requests.
Functions
Item
Nginx Ingress
Positioning
Layer 7 traffic governance offers various advanced routing functions.
  • Layer 7 traffic governance offers various advanced routing functions. It seamlessly incorporates cloud-native technologies to deliver fully managed load balancing services that are O&M-free, highly available, high-performance, and ultra-secure, and support multiple protocols.
  • Computing resources can be scaled to handle traffic surges.
  • ELB can handle tens of millions of concurrent connections and millions of new connections.
Basic routing
  • Routing can be based on content and source IP addresses.
  • Features, such as HTTP header modification, redirection, rewriting, rate limiting, cross-region routing, and sticky sessions, are available.
  • Forwarding rules can be configured for both requests and responses, and the rules for responses can be configured using extended Snippet.
  • Forwarding rules are matched based on the longest path. If multiple paths are matched, the longest forwarding path is prioritized.
  • Features, such as HTTP header modification, redirection, rewriting, rate limiting, and sticky sessions, are available.
  • Forwarding rules can be configured for both requests and responses.
  • Forwarding rules are prioritized in descending order. If multiple paths are matched, a lower value indicates a higher priority.
Protocol
  • HTTP and HTTPS
  • WebSocket, WSS, and gRPC
  • HTTP and HTTPS
  • gRPC
Configuration modification
  • Processes must be reloaded for non-backend endpoint changes. This causes loss to persistent connections.
  • Lua supports hot updates of endpoint changes.
  • Processes must be reloaded for a Lua modification.
The declarative OpenAPI between cloud services enables the dynamic loading of modified configurations to ELB.
Authentication
  • Basic authentication
  • OAuth
TLS authentication
Performance
  • Both system and Nginx parameters require manual optimization for performance tuning.
  • To ensure proper system running, you must configure a proper number of replicas and resource limits. For more information, see Creating an Nginx Ingress on the Console.
Observability
  • Log collection through Access Log
  • Monitoring and alarm configuration through Prometheus
  • Log access for cloud services through interconnected LTS
  • Auditing key operations
  • Metrics-backed monitoring through interconnected Cloud Eye
  • Alarm rules configurable through interconnected Cloud Eye
O&M
  • Bring-your-own component maintenance and periodic version synchronization from the community
  • Scaling through HPA
  • Proactive configuration for optimization
  • Fully managed and no O&M required
  • Auto scaling for ultra-large capacity, with no configuration needed
  • Auto scaling based on service traffic
Security
  • HTTPS
  • Blocklists and trustlists
  • HTTPS (SSL integrated) at both the frontend and backend, SNI, RSA, ECC dual-certification, TLS 1.3, and TLS cipher suites
  • WAF
  • Anti-DDoS
  • Custom security policies
Service governance
  • Kubernetes-backed service discovery
  • Canary release
  • Rate limiting for service HA
  • Canary release
