Help Center/ Cloud Container Engine_Autopilot/ User Guide/ Helm Charts/ API Resource Restrictions on a Chart
Updated on 2025-05-20 GMT+08:00
Resource
Restriction Item
Recommended Alternative Solution
namespaces
Supported
For security purposes, CCE Autopilot does not allow you to deployment workloads in the system namespace (such as kube-system). Also, you cannot create, modify, delete, or execute any resources.
nodes
Supported
You can query nodes but cannot create, delete, and modify nodes.
persistentvolumeclaims
Supported
persistentvolumes
Supported
pods
hostPath
Mounting a file on the local host to a pod is not allowed.
Use emptyDir or cloud storage.
HostNetwork
Mapping the host port to a pod is not allowed.
Use load balancing (type=LoadBalancer).
HostPID
Sharing the host's PID namespace to pods is not allowed.
Users are unaware of the node. There is no need to use the restriction item.
HostIPC
Container processes are not allowed to communicate with processes on the host.
NodeName
Scheduling pods to specific nodes is not allowed.
Privileged containers
Not supported
Linux capabilities
SETPCAP, MKNOD, AUDIT_WRITE, CHOWN, DAC_OVERRIDE, FOWNER, FSETID, KILL, SETGID, SETUID, NET_BIND_SERVICE, SYS_CHROOT, SETFCAP, and SYS_PTRACE are supported.
Use allowed values.
Node affinity and anti-affinity
Pods cannot be scheduled to specified nodes or nodes with certain labels, or a batch of pods cannot be scheduled to nodes with certain labels.
The node affinity or the nodeSelector field does not take effect in CCE Autopilot clusters.
  • You do not need to specify a node for scheduling, but you can specify a pod to an AZ.
  • A batch of pods can be scheduled to multiple AZs.
Pod affinity and anti-affinity
Ineffective
You do not need to set this parameter.
allowPrivilegeEscalation (whether privilege escalation is allowed)
Not supported
Keep the default settings.
RuntimeClassName
This parameter does not need to be configured. When RuntimeClassName is specified by an application (except pods), the value is automatically changed to runc supported by the system.
Time zone synchronization (the /etc/localtime file on the host)
Not supported
serviceaccounts
System configurations cannot be modified, and system-defined roles cannot be bound.
services
Services of the NodePort type are not allowed, and only dedicated load balancer can be used for Services.
daemonsets
apps
DaemonSets are not allowed.
Deploy multiple images in a pod using sidecars.
deployments
apps
Supported. The restricted fields are the same as those in pods.
Use allowed values.
replicasets
apps
Use allowed values.
statefulsets
apps
Use allowed values.
cronjobs
batch
Use allowed values.
jobs
batch
Use allowed values.
clusterrolebindings
rbac.authorization.k8s.io
Supported. The system group, system user, and cce-service group cannot be bound.
Use allowed values.
rolebindings
Use allowed values.
storageclasses
storage.k8s.io
OBS and EVS storage classes cannot be created. Other functions are supported.
Use allowed values.
