Help Center/ Cloud Container Engine_Autopilot/ User Guide/ O&M/ Alarm Center/ Configuring Alarms in Alarm Center
Updated on 2025-02-27 GMT+08:00
By using AOM, Alarm Center can promptly detect cluster faults and generate alarms for service stability. Alarm Center provides built-in alarm rules, which can free you from manually configuring alarm rules on AOM. These rules are established based on the extensive cluster O&M experience of our Huawei Cloud container team and can cover container service exceptions, key metric alarms of basic cluster resources, and metric alarms of applications in a cluster to meet your routine O&M requirements.
Only Huawei Cloud accounts, HUAWEI IDs, or IAM users with CCE administrator or FullAccess permissions can perform all operations using Alarm Center. IAM users with the CCE ReadOnlyAccess permission can only view all resources.
Enabling Alarm Center
  1. Click the cluster name to access the cluster console. In the navigation pane on the left, choose Alarm Center.
  2. On the Alarm Rules tab, click Enable Alarm Center. In the window that slides out from the right, select one or more contact groups to manage subscription endpoints and receive alarm messages by group. If no contact group is available, create one by referring to Binding Contact Groups.
  3. Click OK.
    Metric alarm rules can be created in Alarm Center only after the Cloud Native Cluster Monitoring add-on is installed and the AOM Prometheus instance is interconnected. For details about how to enable Monitoring Center, see Enabling Cluster Monitoring.
    Event alarms in Table 1 can be reported only when Kubernetes event collection is enabled in Logging. For details, see Collecting Kubernetes Events.
Configuring Alarm Rules
After Alarm Center is enabled for clusters, you can configure and manage alarm rules.
  1. Log in to the CCE console.
  2. On the cluster list page, click the name of the target cluster to go to the details page.
  3. In the navigation pane on the left, choose Alarm Center. Then, click the Alarm Rules tab and configure and manage alarm rules.
    By default, Alarm Center generates alarm rules for containers. The rules are intended for alarms including event alarms and metric alarms for exceptions. Alarm rules are classified into several sets. You can associate an alarm rule set with multiple contact groups and enable or disable alarm items. An alarm rule set consists of multiple alarm rules. An alarm rule corresponds to the check items for a single exception. Table 1 lists default alarm rules.
Table 1 Default alarm rules
Rule Type
Alarm Item
Alarm Type
Dependency Item
PromQL/Event Name
Load rule set
Abnormal pod
Check whether the pod is running normally.
Metric
sum(min_over_time(kube_pod_status_phase{phase=~"Pending|Unknown|Failed"}[10m]) and count_over_time(kube_pod_status_phase{phase=~"Pending|Unknown|Failed"}[10m]) > 18 )by (namespace,pod, phase, cluster_name, cluster) > 0
Frequent pod restarts
Check whether the pod frequently restarts.
Metric
increase(kube_pod_container_status_restarts_total[5m]) > 3
Unexpected number of Deployment replicas
Check whether the number of Deployment replicas is the same as the expected value.
Metric
(kube_deployment_spec_replicas != kube_deployment_status_replicas_available ) and ( changes(kube_deployment_status_replicas_updated[5m]) == 0)
Unexpected number of StatefulSet replicas
Check whether the number of StatefulSet replicas is the same as the expected value.
Metric
(kube_statefulset_status_replicas_ready != kube_statefulset_status_replicas) and (changes(kube_statefulset_status_replicas_updated[5m]) == 0)
Container CPU usage higher than 80%
Check whether the container CPU usage is higher than 80%.
Metric
100 * (sum(rate(container_cpu_usage_seconds_total{image!="", container!="POD"}[1m])) by (cluster_name,pod,node,namespace,container, cluster) / sum(kube_pod_container_resource_limits{resource="cpu"}) by (cluster_name,pod,node,namespace,container, cluster)) > 80
Container memory usage higher than 80%
Check whether the container memory usage is higher than 80%.
Metric
(sum(container_memory_working_set_bytes{image!="", container!="POD"}) BY (cluster_name, node,container, pod , namespace, cluster) / sum(container_spec_memory_limit_bytes > 0) BY (cluster_name, node, container, pod , namespace, cluster) * 100) > 80
Abnormal container
Check whether the container is running normally.
Metric
sum by (namespace, pod, container, cluster_name, cluster) (kube_pod_container_status_waiting_reason) > 0
UpdateLoadBalancerFailed
Check whether a load balancer is updated.
Event
Cloud Native Log Collection
N/A
Pod OOM
Check whether an OOM occurs in the pod.
Event
CCE Node Problem Detector
PodOOMKilling
Cluster status rule set
Unavailable cluster
Check whether the cluster is available.
Event
N/A
An alarm rule set can be bound to a maximum of five contact groups.
A contact group, backed on Simple Message Notification, enables message publishers and subscribers to contact each other. A contact group contains one or more terminals. You can bind an alarm rule to a contact group to manage terminals that have subscribed to alarm messages.
  3. In the navigation pane on the left, choose Alarm Center. Then, click the Default Contact Groups tab.
  4. Click Bind Contact Group. You can select a contact group created in SMN or create a contact group. The parameters for creating a contact group are described as follows:
    • Contact Group Name: Enter the name of the contact group, which cannot be changed after the contact group is created. The name can contain 1 to 255 characters and must start with a letter or digit. Only letters, digits, hyphens (-), and underscores (_) are allowed.
    • Alarm Message Display Name: Enter the title of the message received by the specified subscription endpoint. For example, if you set endpoint Type to Email and specify a display name, the name you specified will be displayed as the alarm message sender. If no alarm message display name is specified, the sender will be username@example.com. The alarm message display name can be changed after a contact group is created.
    • Add Subscription endpoint: Add one or more endpoints to receive alarm messages. The endpoint type can be SMS or Email. If you select SMS, enter a valid mobile number. If you select Email, enter a valid email address.
  5. Click OK.
    You will be redirected to the contact group list. The subscription endpoint is in the Unconfirmed state. Send a subscription request to the endpoint to verify its validity.
  6. Click Request Confirmation in the Operation column to send a subscription request to the endpoint. After the endpoint receives and confirms the request, the subscription endpoint status changes to Confirmed.
Viewing Alarms
You can view the latest historical alarms on the Alarm list tab.
  3. In the navigation pane on the left, choose Alarm Center. Then, click the Alarms tab.
    By default, all alarms to be cleared are displayed in the list. You can query alarms by alarm keyword, alarm severity, or alarm time. In addition, you can view the distribution of alarms that meet the specified criteria in different periods.
    If you confirm that an alarm has been handled, click Clear in the Operation column. After the alarm is cleared, you can view it in the historical alarm list.
    Figure 1 Querying alarms
