Configuring OBS Mount Options
This section describes how to configure OBS volume mount options. You can configure mount options in a PV and bind the PV to a PVC. Alternatively, configure mount options in a StorageClass and use the StorageClass to create a PVC. In this way, PVs can be dynamically created and inherit mount options configured in the StorageClass by default.
OBS Mount Options
When mounting an OBS volume, the Everest add-on presets the options described in Table 1 and Table 2 by default. The options in Table 1 are mandatory.
Parameter |
Value |
Description |
use_ino |
Leave it blank. |
If enabled, obsfs allocates the inode number. Enabled by default in read/write mode. |
big_writes |
Leave it blank. |
If configured, the maximum size of the cache can be modified. |
nonempty |
Leave it blank. |
Allows non-empty mount paths. |
allow_other |
Leave it blank. |
Allows other users to access the parallel file system. |
no_check_certificate |
Leave it blank. |
Disables server certificate verification. |
sigv2 |
Leave it blank. |
Specifies the signature version. Used by default in object buckets. |
public_bucket |
1 |
If this parameter is set to 1, public buckets are mounted anonymously. Enabled by default in object bucket read-only mode. |
Parameter |
Value |
Description |
max_write |
131072 |
This parameter is valid only when big_writes is configured. The recommended value is 128 KB. |
ssl_verify_hostname |
0 |
Disables SSL certificate verification based on the host name. |
max_background |
100 |
Allows setting the maximum number of waiting requests in the background. Used by default in parallel file systems. |
umask |
0 |
Mask of the configuration file permission. For example, if the umask value is 022, the directory permission (the maximum permission is 777) is 755 (777 – 022 = 755, rwxr-xr-x). |
Configuring Mount Options in a PV
You can use the mountOptions field to configure mount options in a PV. The options you can configure in mountOptions are listed in OBS Mount Options.
- Use kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
- Configure mount options in a PV. The following is an example:
apiVersion: v1 kind: PersistentVolume metadata: annotations: pv.kubernetes.io/provisioned-by: everest-csi-provisioner everest.io/reclaim-policy: retain-volume-only # (Optional) The underlying storage is retained when the PV is deleted. name: pv-obs # PV name. spec: accessModes: - ReadWriteMany # Access mode. The value must be ReadWriteMany for OBS. capacity: storage: 1Gi # OBS volume capacity. csi: driver: obs.csi.everest.io # Dependent storage driver for the mounting. fsType: obsfs # Instance type. volumeHandle: <your_volume_id> # Name of the OBS volume. volumeAttributes: storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner everest.io/obs-volume-type: STANDARD everest.io/region: <your_region> # Region where the OBS volume is located. everest.io/enterprise-project-id: <your_project_id> # (Optional) Enterprise project ID. This parameter is only available for enterprise accounts with enterprise projects enabled. If an enterprise project is specified, you must specify the same enterprise project when creating a PVC. Otherwise, the PVC will not bind to a PV. nodePublishSecretRef: # Custom secret of the OBS volume. name: <your_secret_name> # Custom secret name. namespace: <your_namespace> # Namespace of the custom secret. persistentVolumeReclaimPolicy: Retain # Reclaim policy. storageClassName: csi-obs # Storage class name. mountOptions: # Mount options. - umask=027 - After a PV is created, you can create a PVC and bind it to the PV, and then mount the PV to the container in the workload. For details, see Using an Existing OBS Bucket or Parallel File System Through a Static PV.
Configuring Mount Options in a StorageClass
You can use the mountOptions field to configure mount options in a StorageClass. The options you can configure in mountOptions are listed in OBS Mount Options.
- Create a customized StorageClass. Example:
kind: StorageClass apiVersion: storage.k8s.io/v1 metadata: name: csi-obs-mount-option provisioner: everest-csi-provisioner parameters: csi.storage.k8s.io/csi-driver-name: obs.csi.everest.io csi.storage.k8s.io/fstype: s3fs everest.io/obs-volume-type: STANDARD reclaimPolicy: Delete volumeBindingMode: Immediate mountOptions: # Mount options. - umask=027
- After the StorageClass is configured, you can use it to create a PVC. By default, the dynamically created PVs inherit the mount options configured in the StorageClass. For details, see Using an Existing OBS Bucket or Parallel File System Through a Static PV.
