Add-ons
Check Items
Check the following items:
- Check whether the add-on status is normal.
- Check whether the add-on supports the target version.
Solution
- Scenario 1: The add-on malfunctions.
Log in to the CCE console, click the cluster name to access the cluster console, and choose Add-ons in the navigation pane to check and handle the abnormal add-on.
- Scenario 2: The target cluster version does not support the add-on.
The following error information is displayed during the pre-upgrade check:
addon [***] does not support cluster target version, check and try again
Log in to the CCE console, click the cluster name to access the cluster console, choose Add-ons in the navigation pane, and manually uninstall the add-on. For details about the supported add-on versions and replacement solutions, see Add-ons.
- Scenario 3: The add-on configuration does not meet the upgrade requirements. Upgrade the add-on and try again.
please upgrade addon [ ] in the page of addon managecheck and try again
Log in to the CCE console, choose Add-ons in the navigation pane, and manually upgrade the add-on.
