Configuring SFS Volume Mount Options
This section describes how to configure SFS volume mount options. You can configure mount options in a PV and bind the PV to a PVC. Alternatively, configure mount options in a StorageClass and use the StorageClass to create a PVC. In this way, PVs can be dynamically created and inherit mount options configured in the StorageClass by default.
Not all regions support SFS volumes. View the regions where SFS volumes are supported on the console. Before using a general-purpose file system (SFS 3.0 Capacity-Oriented) for storage, ensure that a VPC endpoint for the cluster to access the file system has been created in the VPC where the cluster is running. For details, see Configuring a VPC Endpoint.
CCE Autopilot presets the options described in Table 1 for mounting SFS volumes.
| Parameter | Value | Description |
| keep-original-ownership | Leave it blank. | Whether to retain the ownership of the file mount point.
| vers | 3 | File system version. Currently, only NFSv3 is supported. Value: 3 |
| nolock | Leave it blank. | Whether to lock files on the server using the NLM protocol. If nolock is selected, the lock is valid for applications on one host. For applications on another host, the lock is invalid. |
| timeo | 600 | Waiting time before the NFS client retransmits a request. The unit is 0.1 seconds. Recommended value: 600 |
| hard/soft | Leave it blank. | Mount mode.
The default value is hard. |
| sharecache/nosharecache | Leave it blank. | How the data cache and attribute cache are shared when one file system is concurrently mounted to different clients. If this parameter is set to sharecache, the caches are shared between the mountings. If this parameter is set to nosharecache, the caches are not shared, and one cache is configured for each client mounting. The default value is sharecache. NOTE: The nosharecache setting will affect the performance. The mounting information must be obtained for each mounting, which increases the communication overhead with the NFS server and the memory consumption of the NFS clients. In addition, the nosharecache setting on the NFS clients may lead to inconsistent caches. Determine whether to use nosharecache based on site requirements. |
You can set other mount options if needed. For details, see Mounting a General-Purpose File System to Linux ECSs.
Configuring Mount Options
You can configure mount options using either method.
You can use the mountOptions field to configure mount options in a PV. The options you can configure in mountOptions are listed in SFS Volume Mount Options.
- Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
- Configure mount options in a PV.
The following is an example:
apiVersion: v1 kind: PersistentVolume metadata: annotations: pv.kubernetes.io/provisioned-by: everest-csi-provisioner everest.io/reclaim-policy: retain-volume-only # (Optional) The underlying storage is retained when the PV is deleted. name: pv-sfs spec: accessModes: - ReadWriteMany # Access mode. The value must be ReadWriteMany for SFS. capacity: storage: 1Gi # SFS volume capacity. csi: driver: nas.csi.everest.io # Dependent storage driver for the mounting fsType: nfs volumeHandle: <your_volume_id> # Enter the name of the general purpose file system (formerly SFS 3.0 Capacity-Oriented) is used. volumeAttributes: everest.io/share-export-location: <your_location> # Shared path of the SFS volume. storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner everest.io/sfs-version: sfs3.0 # A general-purpose file system (formerly SFS 3.0 Capacity-Oriented) is used for storage. persistentVolumeReclaimPolicy: Retain # Reclaim policy. storageClassName: csi-sfs # StorageClass name, where csi-sfs indicates general purpose file systems (formerly SFS 3.0 Capacity-Oriented). mountOptions: # Mount options. - vers=3 - nolock - timeo=600 - hard - After a PV is created, you can create a PVC and bind it to the PV, and then mount the PV to the container in the workload. For details, see Creating an SFS Volume Statically.
- Check whether the mount options take effect. In this example, the PVC is mounted to the workload that uses the nginx:latest image. You can run the mount -l command to check whether the mount options take effect.
- View the pod to which the SFS volume has been mounted. In this example, the workload name is web-sfs.
kubectl get pod | grep web-sfs
Command output:
web-sfs-*** 1/1 Running 0 23m
- Run the following command to check the mount options (web-sfs-*** is an example pod):
kubectl exec -it web-sfs-*** -- mount -l | grep nfsIf the mounting information in the command output is consistent with the configured mount options, the mount options have been configured.
<Your shared path> on /data type nfs (rw,relatime,vers=3,rsize=1048576,wsize=1048576,namlen=255,hard,nolock,noresvport,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=**.**.**.**,mountvers=3,mountport=2050,mountproto=tcp,local_lock=all,addr=**.**.**.**)
You can use the mountOptions field to configure mount options in a StorageClass. The options you can configure in mountOptions are listed in SFS Volume Mount Options.
- Create a customized StorageClass. Example:
apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: csi-sfs-mount-option provisioner: everest-csi-provisioner parameters: csi.storage.k8s.io/csi-driver-name: nas.csi.everest.io csi.storage.k8s.io/fstype: nfs everest.io/share-access-to: <your_vpc_id> # VPC ID of the cluster. everest.io/sfs-version: sfs3.0 # A general-purpose file system (formerly SFS 3.0 Capacity-Oriented) is used for storage. reclaimPolicy: Delete volumeBindingMode: Immediate mountOptions: # Mount options - vers=3 - nolock - timeo=600 - hard
- After the StorageClass is configured, you can use it to create a PVC. By default, the dynamically created PVs inherit the mount options configured in the StorageClass. For details, see Creating an SFS Volume Dynamically.
- Check whether the mount options are effective. In this example, the PVC is mounted to the workload that uses the nginx:latest image. You can run the mount -l command to check whether the mount options take effect.
Command output:
