Updated on 2025-12-04 GMT+08:00
Using kubectl to Create a LoadBalancer Ingress
An Nginx workload is used as an example to describe how to create a LoadBalancer Ingress using kubectl.
  • A workload is available in the cluster (because an ingress enables network access for workloads). If no workload is available, deploy an Nginx workload by referring to Creating a Workload.
  • A Service has been configured for the workload.
  • Dedicated load balancers can route HTTP/HTTPS traffic at the application layer, and each of them has a private IP address bound.
Creating an ingress with an Automatically Created Load Balancer
The following describes how to run the kubectl command to automatically create a load balancer when creating an ingress.
  1. Use kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    Example of using a dedicated load balancer on a public network:
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/elb.class: performance
        kubernetes.io/elb.port: '80'
        kubernetes.io/elb.autocreate:
              "type": "public",
              "bandwidth_name": "cce-bandwidth-******",
              "bandwidth_chargemode": "bandwidth",
              "bandwidth_size": 5,
              "bandwidth_sharetype": "PER",
              "eip_type": "5_bgp",
              "elb_virsubnet_ids":["*****"],
              "available_zone": [
                  "ap-southeast-1a"
              "l7_flavor_name": "L7_flavor.elb.s1.small"
      rules:
      - host: ''
        http:
          paths:
          - path: '/'
            backend:
              service:
                name: <your_service_name>  # Replace it with the name of your target Service.
                port:
                  number: <your_service_port>  # Replace it with the port number of your target Service.
            property:
      ingressClassName: cce
    Table 1 Key parameters
    Mandatory
    Type
    Yes
    String
    The value can be:
    • performance: dedicated load balancer
    ingressClassName
    Yes
    String
    cce: A LoadBalancer ingress is used.
    This parameter is mandatory when you create an ingress by calling the API.
    No
    Integer
    This parameter indicates the external port registered with the address of the LoadBalancer Service.
    The value ranges from 1 to 65535. The default value is 80 for HTTP and 443 for HTTPS.
    Some ports are high-risk ports and are blocked by default, for example, port 21.
    kubernetes.io/elb.subnet-id
    No
    String
    ID of the subnet where the cluster is located. The value can contain 1 to 100 characters.
    For details, see What Are the Differences Between the VPC Subnet API and the OpenStack Neutron Subnet API?
    kubernetes.io/elb.enterpriseID
    No
    String
    ID of the enterprise project for the load balancer. It is only applicable to enterprise accounts with enterprise projects enabled. After an enterprise project ID is selected, resources can be created in the ELB enterprise project.
    The value contains 1 to 100 characters.
    How to obtain:
    Log in to the EPS console, click the name of the target enterprise project. On the enterprise project details page, find the ID field and copy the ID.
    Yes
    elb.autocreate object
    Whether to automatically create a load balancer associated with an ingress. For details about the field description, see Table 2.
    Example
    • Automatically created dedicated load balancer with an EIP bound:
      '{"type":"inner","available_zone":["*****"],"elb_virsubnet_ids":["*****"],"l7_flavor_name":"L7_flavor.elb.pro.max","l4_flavor_name":"","vip_subnet_cidr_id":"*****"}'
    • Automatically created dedicated load balancer with no EIP bound:
      {"type":"inner","name":"A-location-d-test"}
    kubernetes.io/elb.tags
    No
    String
    Add resource tags to a load balancer. This parameter can be configured only when a load balancer is automatically created.
    A tag is in the format of "key=value". Use commas (,) to separate multiple tags.
    host
    No
    String
    Domain name for accessing the Service. By default, this parameter is left blank, and the domain name needs to be fully matched. Ensure that the domain name has been registered and licensed. Once the domain name is specified, it must be used for access.
    path
    Yes
    String
    User-defined route path. All external access requests must match host and path.
    The access path added here must exist in the backend application. Otherwise, the forwarding fails.
    For example, the default access URL of the Nginx application is /usr/share/nginx/html. When adding /test to the ingress forwarding policy, ensure the access URL of your Nginx application contains /usr/share/nginx/html/test. Otherwise, error 404 will be returned.
    No
    String
    Route matching policy.
    Default: STARTS_WITH (prefix match)
    Options:
    • EQUAL_TO: exact match
    • STARTS_WITH: prefix match
    • REGEX: regular expression match
    pathType
    Yes
    String
    Path type. The options are as follows:
    • ImplementationSpecific: The matching method depends on Ingress Controller. The matching method defined by ingress.beta.kubernetes.io/url-match-mode is used in CCE.
    • Exact: exact matching of the URL, which is case-sensitive.
    • Prefix: prefix matching, which is case-sensitive. With this method, the URL path is separated into multiple elements by slashes (/) and the elements are matched one by one. If each element in the URL matches the path, the subpaths of the URL can be routed normally.
      • During prefix matching, each element must be exactly matched. If the last element of the URL is the substring of the last element in the request path, no matching is performed. For example, /foo/bar matches /foo/bar/baz but does not match /foo/barbaz.
      • When elements are separated by slashes (/), if the URL or request path ends with a slash (/), the slash (/) at the end is ignored. For example, /foo/bar matches /foo/bar/.
    See examples of Ingress path matching.
    Table 2 elb.autocreate data structure
    Mandatory
    Type
    name
    No
    String
    Name of the automatically created load balancer.
    The value can contain 1 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed.
    Default: cce-lb+service.UID
    type
    No
    String
    Network type of the load balancer.
    • public: public network load balancer
    • inner: private network load balancer
    Default: inner
    bandwidth_name
    Yes for public network load balancers
    String
    Bandwidth name. The default value is cce-bandwidth-******.
    String
    Bandwidth billing option.
    • bandwidth: billed by bandwidth
    • traffic: billed by traffic
    Default: bandwidth
    bandwidth_size
    Integer
    Bandwidth size. The default value is 1 to 2,000 Mbit/s. Configure this parameter based on the bandwidth range allowed in your region.
    The minimum increment for bandwidth adjustment varies depending on the bandwidth range.
    • The minimum increment is 1 Mbit/s if the allowed bandwidth does not exceed 300 Mbit/s.
    • The minimum increment is 50 Mbit/s if the allowed bandwidth ranges from 300 Mbit/s to 1,000 Mbit/s.
    • The minimum increment is 500 Mbit/s if the allowed bandwidth exceeds 1,000 Mbit/s.
    bandwidth_sharetype
    String
    Bandwidth sharing mode.
    • PER: dedicated bandwidth
    eip_type
    String
    EIP type.
    • 5_telcom: China Telecom
    • 5_union: China Unicom
    • 5_bgp: dynamic BGP
    • 5_sbgp: static BGP
    vip_subnet_cidr_id
    No
    String
    Specifies the subnet where a load balancer is located. The subnet must belong to the VPC where the cluster resides.
    If this parameter is not specified, the ELB load balancer and the cluster are in the same subnet.
    vip_address
    No
    String
    Specifies the private IP address of the load balancer. Only IPv4 addresses are supported. IPv6 addresses are not supported.
    The IP address must be in the CIDR block of the load balancer. If this parameter is not specified, an IP address will be automatically assigned from the CIDR block of the load balancer.
    available_zone
    Yes
    Array of strings
    AZ where the load balancer is located.
    You can obtain all supported AZs by querying the AZ list.
    This parameter is only available for dedicated load balancers.
    l4_flavor_name
    Yes
    String
    Flavor name of the Layer-4 load balancer.
    You can obtain all supported types by calling the API for querying the flavor list.
    l7_flavor_name
    No
    String
    Flavor name of the Layer-7 load balancer.
    This parameter is available only for dedicated load balancers. The value of this parameter must be the same as that of l4_flavor_name, that is, both are elastic specifications or fixed specifications.
    elb_virsubnet_ids
    No
    Array of strings
    The network ID of the subnet where the load balancer is located. This subnet is used to allocate IP addresses for accessing the backend server. If this parameter is not specified, the subnet specified by vip_subnet_cidr_id will be used by default. Load balancers occupy different number of subnet IP addresses based on their specifications. Do not use the subnet CIDR blocks of other resources (such as clusters and nodes) as the load balancer CIDR block.
    Example:
    "elb_virsubnet_ids": [
       "14567f27-8ae4-42b8-ae47-9f847a4690dd"
    How to obtain:
    Log in to the VPC console. In the navigation pane, choose Subnets. Filter the target subnet by the cluster's VPC name, click the subnet name, and copy the Network ID on the Summary tab.
  3. Create an ingress.
    If information similar to the following is displayed, the Ingress has been created.
    ingress/ingress-test created
    kubectl get ingress
    If information similar to the following is displayed, the Ingress has been created, and the workload is accessible.
    NAME             HOSTS     ADDRESS          PORTS   AGE
    ingress-test     *         121.**.**.**     80      10s
  4. Enter http://121.**.**.**:80 in the address box of the browser to access the workload.
    121.**.**.** indicates the IP address of the unified load balancer.
Creating an ingress with an Existing Load Balancer
CCE allows you to connect to an existing load balancer when creating an ingress.
The YAML file is configured as follows:
kind: Ingress
  annotations:
    kubernetes.io/elb.id: <your_elb_id>  # Replace it with the ID of your existing load balancer.
    kubernetes.io/elb.ip: <your_elb_ip>  # Replace it with the IP of your existing load balancer.
    kubernetes.io/elb.class: performance  # Load balancer type
  rules:
  - host: ''
    http:
      paths:
      - path: '/'
        backend:
          service:
            port:
              number: 8080             # Replace 8080 with the port number of your target Service.
        property:
Table 3 Key parameters
Mandatory
Type
Use either this parameter or kubernetes.io/elb.ip.
String
Load balancer ID. The value can contain 1 to 100 characters.
How to obtain:
On the management console, click Service List, and choose Networking > Elastic Load Balance. Click the name of the load balancer. On the Summary tab, find and copy the ID.
Use either this parameter or kubernetes.io/elb.id.
String
IP address of the load balancer. Use either this parameter or kubernetes.io/elb.id. If they conflict, kubernetes.io/elb.id will take precedence.
When creating an ingress, you can only specify a private IP address for the associated dedicated load balancer.
Yes
String
Load balancer type.
If a LoadBalancer Ingress accesses an existing dedicated load balancer, the dedicated load balancer must be of the application load balancing (HTTP/HTTPS) type.
