- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
On this page
Show all
Help Center/
Cloud Container Engine_Autopilot/
User Guide/
Clusters/
Managing a Cluster/
Deleting a Cluster
Deleting a Cluster
Precautions
- Deleting a cluster will delete the workloads and Services in the cluster, and the deleted data cannot be recovered. Before performing this operation, ensure that data has been backed up or migrated. Deleted data cannot be restored.
- If you delete a cluster that is not in the Running state (for example, Frozen or Unavailable), associated resources, such as storage and networking resources, will remain.
Deleting a Cluster
- Log in to the CCE console. In the navigation pane, choose Clusters.
- Locate the cluster to be deleted, click ... to view more operations on the cluster, and choose Delete.
- In the displayed Delete Cluster dialog box, select the resources to be released.
- Delete cloud storage resources (bound to PVs) in a cluster.
- Delete network resources such as load balancers in a cluster. (Only automatically created load balancers will be deleted).
- By default, the resources (such as VPC endpoints, NAT gateways, and EIPs specified in the SNAT rules) created in the VPC of the cluster are retained. Ensure that the resources are not reused by other clusters or Services and delete them on the network console.
- Click Yes to start deleting the cluster.
The delete operation takes 1 to 3 minutes to complete.
Parent Topic: Managing a Cluster
