Help Center/ Cloud Container Engine_Autopilot/ User Guide/ Add-ons/ CCE Container Storage (Everest)
Updated on 2025-02-27 GMT+08:00
Introduction
Everest is a cloud native container storage add-on that enables Kubernetes clusters to access cloud storage services through CSI.
In clusters of v1.27.5-r0, v1.28.3-r0, and later versions, this add-on is automatically configured by the system and does not need to be manually installed or updated.
Editing the Add-on
This add-on is installed by default. To modify its settings, perform the following steps:
  1. Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane on the left, choose Add-ons. Locate CCE Container Storage (Everest) on the right and click Edit.
  2. On the Edit Add-on page, modify the specifications.
    Table 1 Everest specifications
    Pods
    Number of pods for the add-on.
    High availability is not possible if there is only one pod. If an error occurs on the node where the pod runs, the add-on will fail.
    CPU and memory quotas of the containers for running the add-on. The add-on contains the everest-csi-controller and everest-csi-driver components. For details, see Components.
  3. Modify the parameters.
    Table 2 Everest parameters
    csi_attacher_worker_threads
    Number of worker nodes that can be concurrently processed by Everest for attaching EVS volumes. The default value is 60.
    csi_attacher_detach_worker_threads
    Number of worker nodes that can be concurrently processed by Everest for detaching EVS volumes. The default value is 60.
    volume_attaching_flow_ctrl
    Maximum number of EVS volumes that can be attached by the Everest add-on within 1 minute. The default value is 0, indicating that the performance of attaching EVS volumes is determined by the underlying storage resources.
    cluster_id
    Cluster ID
    default_vpc_id
    ID of the VPC to which the cluster belongs
    disable_auto_mount_secret
    Whether the default AK/SK can be used when an object bucket or parallel file system is mounted. The default value is false.
    enable_node_attacher
    Whether to enable the attacher on the agent to process the VolumeAttachment.
    flow_control
    This field is left blank by default. You do not need to configure this parameter.
    over_subscription
    Overcommitment ratio of the local storage pool (local_storage). The default value is 80. If the size of the local storage pool is 100 GiB, it can be overcommitted to 180 GiB.
    project_id
    ID of the project to which a cluster belongs
    The performance of attaching a large number of EVS volumes has been optimized. The following parameters can be configured:
    • csi_attacher_worker_threads
    • csi_attacher_detach_worker_threads
    • volume_attaching_flow_ctrl
    The preceding parameters are associated with each other and are constrained by the underlying storage resources in the region where the cluster is located. To attach a large number of volumes (more than 500 EVS volumes per minute), contact customer service and configure the parameters under their guidance to prevent the Everest add-on from running abnormally due to improper parameter settings.
  4. Click OK.
Components
Table 3 Everest components
Component
Resource Type
Used to create, delete, snapshot, expand, attach, and detach storage volumes.
Deployment
everest-csi-driver
Used to mount and unmount PVs and resize file systems.
DaemonSet
