Updated on 2026-03-12 GMT+08:00
Creating a Hybrid Cloud 2.0 Replication Vault
Before starting a cross-cloud replication, you need to create a hybrid cloud 2.0 replication vault in the target region of the target cloud to store the replicas.
  • Hybrid cloud 2.0 replication vaults can only receive cloud server backups and SFS Turbo backups from the source cloud.
  • When you create an encrypted hybrid cloud 2.0 replication vault, RAM keys cannot be used for encryption.
  • If the hybrid cloud 2.0 replication vault on the target cloud is encrypted, cross-cloud replicated backups will be automatically encrypted with the keys of the hybrid cloud 2.0 replication vault on the target cloud.
  • Policies cannot be applied to hybrid cloud 2.0 replication vaults. If you want to replicate replicated backups to other regions or a region of the source cloud, you can only manually replicate the backups.
  • A hybrid cloud 2.0 replication vault cannot be associated with resources, and its data cannot be migrated to other vaults.
Purchasing a Hybrid Cloud 2.0 Replication Vault
  1. Log in to the CBR console.
    2. In the upper left corner, click and select a region.
    3. Click and choose Storage > Cloud Backup and Recovery. Then, select Hybrid Cloud Backups 2.0.
  2. Click Create Hybrid Cloud Backup Vault in the upper right corner.
  3. Set the required parameters for purchasing a hybrid cloud 2.0 replication vault. Retain the default values for other parameters.
    Complete Basic Settings and select a Protection Type.
    Example Value
    Billing Mode
    Pay-per-use
    • Pay-per-use is a postpaid billing mode. You are billed based on your resource usage. You can buy or delete vaults anytime. Fees are deducted from your account.
    • Yearly/Monthly is a prepaid billing mode. You are billed based on the subscription duration you specify. This mode provides lower prices and is ideal when the resource use duration is predictable.
    Region
    AP-Bangkok
    Target region where the backups will be replicated to. Resources in different regions cannot communicate with each other over internal networks.
    Once the vault is created, its region cannot be changed.
    Protection Type
    Replication
    Replication: A replication vault stores replicas generated during backup replication.
    Encryption
    Disabled
    When this function is enabled, all backups are stored in encrypted mode. You can select a key from the KMS key list or enter the KMS key ID of the current region.
    Only keys generated using the AES-256 or SM4 encryption algorithm can be used.
    Set the Backup Capacity.
    Example Value
    Backup Capacity
    1TB
    Specify the vault capacity. The value ranges from 1 TB to 10,240 TB.
    You need to plan the vault capacity in advance. The capacity of the replication vault cannot be less than the size of the backups to be replicated.
    As the vault's used space grows, you can expand the vault capacity if it becomes insufficient.
    Configure Enterprise Project and Advanced Settings.
    Example Value
    Enterprise Project
    default
    Add the vault to an existing enterprise project. EPS provides a unified method to manage cloud resources by project, allowing you to manage resources, users, and user groups in your projects. The default enterprise project is named default.
    This parameter is only available for enterprise users who have enabled enterprise project management.
    If IAM users have been assigned the CBR FullAccess permissions but cannot choose enterprise projects when they create a vault, the administrator needs to go to the Enterprise Project Management console to assign the CBR FullAccess permissions to the IAM user groups.
    Vault Name
    vault-317a
    Specify the name of the vault to be created.
    The vault name can contain 1 to 64 characters. Only letters, digits, underscores (_), and hyphens (-) are allowed. You can also use the default name vault_xxxx.
  4. Click Next.
  5. Click Submit.
  6. Go back to the hybrid cloud 2.0 backup page. You can view the created vault in the vault list. The vault is in the Available state.
