Monitored Events
On Cloud Eye, you can query CBR events and alarms. You can create alarm rules to get notified when specific events happen.
Namespace
SYS.CBR
Monitored Events
Event Name |
Event ID |
Severity |
Description |
Solution |
Impact |
Backup creation failed |
backupFailed |
Critical |
The backup creation failed. |
Manually create the backup or contact technical support. |
Data may be lost. |
Restoration from a backup failed |
restorationFailed |
Critical |
The resource restoration from a backup failed. |
Restore the resource using another backup or contact technical support. |
Data may be lost. |
Backup deletion failed |
backupDeleteFailed |
Critical |
The backup deletion failed. |
Try again later or contact technical support. |
Billing may be abnormal. |
Vault deletion failed |
vaultDeleteFailed |
Critical |
The vault deletion failed. |
Replication failure |
replicationFailed |
Critical |
The backup replication failed. |
Data may be lost. |
Backup created |
backupSucceeded |
Major |
The backup was created. |
None |
None |
Resource restored from a backup |
restorationSucceeded |
Major |
The resource was succcessfully restored from a backup. |
Check that data is successfully restored. |
None |
Backup deleted |
backupDeletionSucceeded |
Major |
The backup was deleted successfully. |
None |
None |
Vault deleted |
vaultDeletionSucceeded |
Major |
The vault was deleted successfully. |
None |
None |
Replication succeeded |
replicationSucceeded |
Major |
The backup was replicated successfully. |
None |
None |
Agent offline |
agentOffline |
Critical |
The Agent is offline. |
Ensure that the Agent is normal and can connect to Huawei Cloud. |
Backup tasks may fail. |
Agent online |
agentOnline |
Major |
The Agent is online. |
None |
None |
