- Billing
- Getting Started
User Guide
- Overview
- Permissions Management
- Environment Management
- Application Management
- Component Management
- Instance Management
- Component Configurations
- Component O&M
- System Settings
- Key Operations Recorded by CTS
Best Practices
- CAE Best Practices
- Using CAE to Host Nginx Static File Servers
- Interconnecting GitLab with Jenkins for Automatic Build and Deployment on CAE
- Deploying Components Based on the Dependency Sequence Using the Jenkins Pipeline
- Deploying Spring Cloud Applications to CAE to Automatically Connect to the Nacos Engine
- Graceful Startup of a Spring Cloud Application
- Health Check
- Lifecycle Management
- Sending Event Alarms to WeCom
Connecting to the CodeArts Pipeline to Automatically Upgrade CAE Components
- Overview
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to a CodeArts Release Repo
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to the OBS Bucket
- Upgrading a CAE Component After Uploading an Image Built Using the Pipeline to the SWR Image Repository
- Configuring PromQL to Implement Custom Auto Scaling
- Configuring the Interconnection Between CAE and DEW to Help Applications Obtain Encrypted Secrets from DEW
- Deploying ASP.NET Core Applications to CAE
- Connecting the Network Through Enterprise Routes
- API Reference
- Component Management FAQs
Component Configuration FAQs
- Is Manual Scaling Still Effective When a Scaling Policy Is Configured?
- Can Components Be Scaled Without a Scaling Policy?
- Why Is My Instance Abnormal After Cloud Storage Is Configured?
- What Do I Do If a Component Becomes Not Ready?
- How Does CAE Support Dark Launch?
- How Do I Provide Prometheus Metrics for a Java Application?
- System Configuration FAQs
- Service Resources FAQs
On this page
Show all
Help Center/
Cloud Application Engine/
User Guide/
Component Configurations/
Configuring an AS Policy/
Disabling an AS Policy
Disable an AS policy that is no longer needed. After the AS policy is disabled, instances will not be automatically scaled.
Disable the AS policy before stopping a component or configuring manual scaling.
- Log in to CAE.
- Choose Component Configurations.
- Select the target component from the drop-down list in the upper part of the page.
Figure 1 Selecting a component
- Click Edit in the AS Policies module.
- Click
. A message is displayed indicating that the AS policy is disabled.
- Click OK.
- In the displayed dialog box, enter SWITCHOFF and click OK.
- Click Activate Settings in the upper part of the page. In the dialog box displayed on the right, confirm the configurations and click OK for the configurations to take effect.
Parent topic: Configuring an AS Policy
